Upon rebooting my ubuntu machine remotely over ssh, I was no longer able to ssh to that machine. It was suggested that this was due to my home directory being encrypted with the authorized_keys locked inside it. So I took the same suggestion verbatim and added AuthorizedKeysFile /etc/ssh/.authorized_keys to my sshd_config.
But then I got Permission denied (publickey) on any ssh attempt including ssh localhost, with "Failed publickey for myusername from 192.168.1.8 port 63398 ssh2" in the /var/log/auth.log. The only way I found to fix this is to comment out the AuthorizedKeysFile setting (and maybe also do sudo service ssh restart). Of course this brings back my original problem with ssh-ing after reboot.
My /etc/ssh/.authorized_keys has permissions 600 just like the original ~/.ssh/authorized_keys. Any ideas what is going wrong?
zkurtz
  • 323
You have rightly put:
in /etc/ssh/sshd_config and also correctly moved all the public keys from ~/.ssh/authorized_keys to /etc/ssh/.authorized_keys.
The problem is that /etc/ssh/.authorized_keys is owned by root and a permission of 600 on the file means that only root can read-write the file, not the user you are login as.
To solve the issue make the user owner of the file, if the user is foobar then do:
sudo chown foobar /etc/ssh/.authorized_keys
and keep everything else as it is.
heemayl
  • 93,925
