What I normally do is cd to a location in Terminal, and then run (as instructed here):
nautilus .
If I want to open Nautilus so that it opens up on the location to which I have navigated to in Terminal, however, no matter to where I navigate in 15.10, running the command only ever opens Nautilus in the home folder. If I want it to open a specific location then I have to instead run:
nautilus /path/to/location/
So why am I not able to just run the original command to get there? This is rather inconvenient. Is this a bug? And is there any way of making it work as it did before?
OS Information:
 LSB Version:   core-2.0-amd64:core-2.0-noarch:core-3.0-amd64:core-3.0-noarch:core-3.1-amd64:core-3.1-noarch:core-3.2-amd64:core-3.2-noarch:core-4.0-amd64:core-4.0-noarch:core-4.1-amd64:core-4.1-noarch
 Distributor ID:    Ubuntu
 Description:   Ubuntu 15.10
 Release:   15.10
 Codename:  wily
Package Information:
nautilus:
  Installed: 1:3.18.1-0ubuntu1~wily1
  Candidate: 1:3.18.1-0ubuntu1~wily1
  Version table:
 *** 1:3.18.1-0ubuntu1~wily1 0
        500 http://ppa.launchpad.net/gnome3-team/gnome3-staging/ubuntu/ wily/main amd64 Packages
        100 /var/lib/dpkg/status
     1:3.14.2-0ubuntu12 0
        500 http://archive.ubuntu.com/ubuntu/ wily/main amd64 Packages
Byte Commander
  • 110,243
nautilus . works perfectly using the Nautilus version from the default repositories, so it's probably a bug in the Nautilus version from the GNOME repository.
As a workaround until the bug is fixed, you may use this command to open Nautilus in the current working directory:
nautilus "$PWD"
kos
  • 41,268
