I'd appreciate some insight. I've tried Charles's workaround here: VMware won't work after Ubuntu Upgrade which passes the first hurdle and I get a Kernel upgrade message, but then it fails to update Kernel ... fails on Vmnetwork. Output of CLI below:
Gtk-Message: Failed to load module "canberra-gtk-module": libcanberra-gtk-module.so: cannot open shared object file: No such file or directory
failed
make[1]: *** [_module_/tmp/modconfig-TrwoH8/vmnet-only] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-4.2.0-16-generic'
Makefile:120: recipe for target 'vmnet.ko' failed
make: *** [vmnet.ko] Error 2
make: Leaving directory '/tmp/modconfig-TrwoH8/vmnet-only'
Starting VMware services:
   Virtual machine monitor                                             done
   Virtual machine communication interface                             done
   VM communication interface socket family                            done
   Blocking file system                                                done
   Virtual ethernet                                                   failed
   VMware Authentication Daemon                                        done
Jakuje
  • 6,793
Tony M
I solved it doing.
after kernel 4.4 (VMWare Workstation 12) need some changes in c code:
/usr/lib/vmware/modules/source
1) vmmon.tar
  • untar
  • change ./vmmon-only/linux/hostif.c
  • replace all:
    "get_user_pages" to "get_user_pages_remote"
  • tar and replace original
2) vmnet.tar
  • untar
  • change ./vmnet-only/userif.c
  • replace all:
Successful compiled on FC23 FC24, FC25 (kernel 4.7)
https://communities.vmware.com/message/2598402#2598402
Yoduro
