I need the ia32-libs packages because Petalinux SDK requires it.
I have just updated to Ubuntu 15.10 today, and now it won't let me install this package. I've installed it before on Ubuntu 15.04, so there should be no reason why it won't install on 15.10, right?
I've added the correct file to the sources.list.d directory.
┌─[♨ steven ♨ ][~]
└─(20:38)(pts/2) Prometheus ─╼ cat /etc/apt/sources.list.d/ia32-libs-raring.list
deb http://old-releases.ubuntu.com/ubuntu/ raring main restricted universe multiverse
I did an update and tried to install the package, but this is all that happens...
┌─[♨ steven ♨ ][~]
└─(20:41)(pts/2) Prometheus ─╼ sudo apt-get install ia32-libs
Reading package lists... Done
Building dependency tree
ia32-libs : Depends: ia32-libs-multiarch
┌─[♨ steven ♨ ][~]
└─:( (20:42)(pts/2) Prometheus ─╼ sudo apt-get install ia32-libs-multiarch
ia32-libs-multiarch:i386 : Depends: bluez-alsa:i386 but it is not going to be installed
However when I try to install the bluez-alsa:i386 package, it tells me it needs bluez:i386. When I try to install that one, it tells me I need bluez-alsa:i386 ... if I try to install both, it tells me they conflict with each other...
Is something broken that I am not seeing? Is support for this ia32-lib package completely gone?
Do I just need to downgrade back to 15.04?
I am running 15.10 64-bit
