I have an issue were vmware player doesnt start when i open it via the launcher. It just does nothing, no error message whatsoever. I got it running once, but now it wont open up.
Im using vmware 64 bit, already tried reinstall via the vmware installer.
Any ideas?
Julian
  • 133
The solution below applies to versions of VMWare prior to 12.1.0. The 12.1.0 version of VMWare does not require this fix.
VMWare and VMPlayer are in fact looking for a specific library string. You can execute VMWare/VMPlayer from the terminal by executing
export LD_LIBRARY_PATH=/usr/lib/vmware/lib/libglibmm-2.4.so.1/:$LD_LIBRARY_PATH
then vmware or vmplayer
I made this a permanent change on my system by executing instead
executing sudo nano /usr/bin/vmware and adding the line
after the line export PRODUCT_NAME...
Press ctrl+o to save and ctrl+x to exit: VMWare will now work.
To perform the same function for VMPlayer, execute the same changes to /usr/bin/vmplayer
Charles Green
  • 21,859
