At first it would open, I was using wine to run it or something like that, like a forum I had read told me, but couldn't play any games due to some drivers issues I believe. Then I tried updating them but when I went to the system update area to update the drivers, there were no available updates to be had. Some more time and troubleshooting had passed and now Steam simply won't even open, saying FATAL ERROR: failed to load steamuo.si and I have literally no idea as to what I have to do. Please help!
Steam in terminal:
[2015-10-27 00:43:49] Startup - updater built May 5 2015 12:15:27
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2015-10-27 00:43:49] Checking for update on startup
[2015-10-27 00:43:49] Checking for available updates...
[2015-10-27 00:43:49] Download complete.
[2015-10-27 00:43:49] uninstalled manifest found in /home/joey/.local/share/Steam/package/steam_client_ubuntu12 (1).
[2015-10-27 00:43:49] Found pending update
[2015-10-27 00:43:49] Installing update...
[2015-10-27 00:43:49] Extracting package...
[2015-10-27 00:44:08] Installing update...
[2015-10-27 00:44:09] BCommitUpdatedFiles: failed to create directory ./steam/cached
lspci | grep VGA in terminal:
00:02.0 VGA compatible controller: Intel Corporation 82G33/G31 Express Integrated Graphics Controller (rev 02)
After "LD_PRELOAD='/usr/$LIB/libstdc++.so.6' DISPLAY=:0 steam"
[2015-10-27 19:43:54] Startup - updater built May 5 2015 12:15:27
[2015-10-27 19:43:54] Checking for update on startup
[2015-10-27 19:43:54] Checking for available updates...
[2015-10-27 19:43:55] Download complete.
[2015-10-27 19:43:55] uninstalled manifest found in /home/joey/.local/share/Steam/package/steam_client_ubuntu12 (1).
[2015-10-27 19:43:55] Found pending update
[2015-10-27 19:43:55] Installing update...
[2015-10-27 19:43:55] Extracting package...
[2015-10-27 19:44:13] Installing update...
[2015-10-27 19:44:14] BCommitUpdatedFiles: failed to create directory ./steam/cached
[2015-10-27 19:44:14] BCommitUpdatedFiles: failed to process ./steam
[2015-10-27 19:44:14] Failed to apply update, reverting...
[2015-10-27 19:44:14] Verifying installation...
[2015-10-27 19:44:14] Performing checksum verification of executable files
[2015-10-27 19:44:14] Unable to read and verify install manifest /home/joey/.local/share/Steam/package/steam_client_ubuntu12.installed
[2015-10-27 19:44:14] Verification complete
[2015-10-27 19:44:14] Downloading update...
[2015-10-27 19:44:14] Checking for available updates...
[2015-10-27 19:44:15] Download complete.
[2015-10-27 19:44:15] Extracting package...
[2015-10-27 19:44:33] Installing update...
[2015-10-27 19:44:34] BCommitUpdatedFiles: failed to create directory ./steam/cached
[2015-10-27 19:44:34] BCommitUpdatedFiles: failed to process ./steam
[2015-10-27 19:44:34] Failed to apply update, reverting...
[2015-10-27 19:44:50] Shutdown
output of command "cd ~/.local/share/Steam/ubuntu12_32"
.local/share/Steam/ubuntu12_32$
After "LD_LIBRARY_PATH=. ldd ~/.steam/ubuntu12_32/steamui.so"
linux-gate.so.1 => (0xf778b000)
libtier0_s.so => not found
libvstdlib_s.so => not found
libv8.so => not found
libvideo.so => not found
libSDL2-2.0.so.0 => not found
libXtst.so.6 => not found
libXfixes.so.3 => /usr/lib/i386-linux-gnu/libXfixes.so.3 (0xf63b0000)
libXrandr.so.2 => /usr/lib/i386-linux-gnu/libXrandr.so.2 (0xf63a2000)
libXext.so.6 => /usr/lib/i386-linux-gnu/libXext.so.6 (0xf638d000)
libX11.so.6 => /usr/lib/i386-linux-gnu/libX11.so.6 (0xf6242000)
libGL.so.1 => /usr/lib/i386-linux-gnu/mesa/libGL.so.1 (0xf61af000)
libgobject-2.0.so.0 => /usr/lib/i386-linux-gnu/libgobject-2.0.so.0 (0xf6150000)
libglib-2.0.so.0 => /lib/i386-linux-gnu/libglib-2.0.so.0 (0xf6028000)
libgtk-x11-2.0.so.0 => /usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0 (0xf5b32000)
librt.so.1 => /lib/i386-linux-gnu/librt.so.1 (0xf5b29000)
libpulse.so.0 => /usr/lib/i386-linux-gnu/libpulse.so.0 (0xf5ad0000)
libgdk_pixbuf-2.0.so.0 => /usr/lib/i386-linux-gnu/libgdk_pixbuf-2.0.so.0 (0xf5aa7000)
libm.so.6 => /lib/i386-linux-gnu/libm.so.6 (0xf5a59000)
libdl.so.2 => /lib/i386-linux-gnu/libdl.so.2 (0xf5a54000)
libstdc++.so.6 => /usr/lib/i386-linux-gnu/libstdc++.so.6 (0xf58dd000)
libpthread.so.0 => /lib/i386-linux-gnu/libpthread.so.0 (0xf58c0000)
/lib/ld-linux.so.2 (0xf778c000)
libc.so.6 => /lib/i386-linux-gnu/libc.so.6 (0xf5705000)
libXrender.so.1 => /usr/lib/i386-linux-gnu/libXrender.so.1 (0xf56f8000)
libxcb.so.1 => /usr/lib/i386-linux-gnu/libxcb.so.1 (0xf56d3000)
libexpat.so.1 => /lib/i386-linux-gnu/libexpat.so.1 (0xf56aa000)
libglapi.so.0 => /usr/lib/i386-linux-gnu/libglapi.so.0 (0xf568f000)
libXdamage.so.1 => /usr/lib/i386-linux-gnu/libXdamage.so.1 (0xf568b000)
libX11-xcb.so.1 => /usr/lib/i386-linux-gnu/libX11-xcb.so.1 (0xf5687000)
libxcb-glx.so.0 => /usr/lib/i386-linux-gnu/libxcb-glx.so.0 (0xf566c000)
libxcb-dri2.so.0 => /usr/lib/i386-linux-gnu/libxcb-dri2.so.0 (0xf5666000)
libxcb-dri3.so.0 => /usr/lib/i386-linux-gnu/libxcb-dri3.so.0 (0xf5662000)
libxcb-present.so.0 => /usr/lib/i386-linux-gnu/libxcb-present.so.0 (0xf565e000)
libxcb-sync.so.1 => /usr/lib/i386-linux-gnu/libxcb-sync.so.1 (0xf5655000)
libxshmfence.so.1 => /usr/lib/i386-linux-gnu/libxshmfence.so.1 (0xf5652000)
libXxf86vm.so.1 => /usr/lib/i386-linux-gnu/libXxf86vm.so.1 (0xf564b000)
libdrm.so.2 => /usr/lib/i386-linux-gnu/libdrm.so.2 (0xf5639000)
libffi.so.6 => /usr/lib/i386-linux-gnu/libffi.so.6 (0xf562f000)
libpcre.so.3 => /lib/i386-linux-gnu/libpcre.so.3 (0xf55bb000)
libgdk-x11-2.0.so.0 => /usr/lib/i386-linux-gnu/libgdk-x11-2.0.so.0 (0xf54fb000)
libgmodule-2.0.so.0 => /usr/lib/i386-linux-gnu/libgmodule-2.0.so.0 (0xf54f6000)
libpangocairo-1.0.so.0 => /usr/lib/i386-linux-gnu/libpangocairo-1.0.so.0 (0xf54e8000)
libatk-1.0.so.0 => /usr/lib/i386-linux-gnu/libatk-1.0.so.0 (0xf54c1000)
libcairo.so.2 => /usr/lib/i386-linux-gnu/libcairo.so.2 (0xf537f000)
libgio-2.0.so.0 => /usr/lib/i386-linux-gnu/libgio-2.0.so.0 (0xf51bd000)
libpangoft2-1.0.so.0 => /usr/lib/i386-linux-gnu/libpangoft2-1.0.so.0 (0xf51a6000)
libpango-1.0.so.0 => /usr/lib/i386-linux-gnu/libpango-1.0.so.0 (0xf5154000)
libfontconfig.so.1 => /usr/lib/i386-linux-gnu/libfontconfig.so.1 (0xf5111000)
libjson-c.so.2 => /lib/i386-linux-gnu/libjson-c.so.2 (0xf5104000)
libpulsecommon-6.0.so => /usr/lib/i386-linux-gnu/pulseaudio/libpulsecommon-6.0.so (0xf507f000)
libdbus-1.so.3 => /lib/i386-linux-gnu/libdbus-1.so.3 (0xf5025000)
libgcc_s.so.1 => /lib/i386-linux-gnu/libgcc_s.so.1 (0xf5007000)
libXau.so.6 => /usr/lib/i386-linux-gnu/libXau.so.6 (0xf5003000)
libXdmcp.so.6 => /usr/lib/i386-linux-gnu/libXdmcp.so.6 (0xf4ffb000)
libXinerama.so.1 => /usr/lib/i386-linux-gnu/libXinerama.so.1 (0xf4ff7000)
libXi.so.6 => /usr/lib/i386-linux-gnu/libXi.so.6 (0xf4fe5000)
libXcursor.so.1 => /usr/lib/i386-linux-gnu/libXcursor.so.1 (0xf4fda000)
libXcomposite.so.1 => /usr/lib/i386-linux-gnu/libXcomposite.so.1 (0xf4fd6000)
libfreetype.so.6 => /usr/lib/i386-linux-gnu/libfreetype.so.6 (0xf4f28000)
libpixman-1.so.0 => /usr/lib/i386-linux-gnu/libpixman-1.so.0 (0xf4e75000)
libpng12.so.0 => /lib/i386-linux-gnu/libpng12.so.0 (0xf4e49000)
libxcb-shm.so.0 => /usr/lib/i386-linux-gnu/libxcb-shm.so.0 (0xf4e45000)
libxcb-render.so.0 => /usr/lib/i386-linux-gnu/libxcb-render.so.0 (0xf4e3a000)
libz.so.1 => /lib/i386-linux-gnu/libz.so.1 (0xf4e1e000)
libselinux.so.1 => /lib/i386-linux-gnu/libselinux.so.1 (0xf4df6000)
libresolv.so.2 => /lib/i386-linux-gnu/libresolv.so.2 (0xf4ddd000)
libharfbuzz.so.0 => /usr/lib/i386-linux-gnu/libharfbuzz.so.0 (0xf4d79000)
libthai.so.0 => /usr/lib/i386-linux-gnu/libthai.so.0 (0xf4d6f000)
libsystemd.so.0 => /lib/i386-linux-gnu/libsystemd.so.0 (0xf4ce2000)
libwrap.so.0 => /lib/i386-linux-gnu/libwrap.so.0 (0xf4cd8000)
libsndfile.so.1 => /usr/lib/i386-linux-gnu/libsndfile.so.1 (0xf4c5f000)
libasyncns.so.0 => /usr/lib/i386-linux-gnu/libasyncns.so.0 (0xf4c58000)
libgraphite2.so.3 => /usr/lib/i386-linux-gnu/libgraphite2.so.3 (0xf4c3a000)
libdatrie.so.1 => /usr/lib/i386-linux-gnu/libdatrie.so.1 (0xf4c31000)
liblzma.so.5 => /lib/i386-linux-gnu/liblzma.so.5 (0xf4c0b000)
libgcrypt.so.20 => /lib/i386-linux-gnu/libgcrypt.so.20 (0xf4b5a000)
libnsl.so.1 => /lib/i386-linux-gnu/libnsl.so.1 (0xf4b3f000)
libFLAC.so.8 => /usr/lib/i386-linux-gnu/libFLAC.so.8 (0xf4ade000)
libvorbisenc.so.2 => /usr/lib/i386-linux-gnu/libvorbisenc.so.2 (0xf4a4f000)
libgpg-error.so.0 => /lib/i386-linux-gnu/libgpg-error.so.0 (0xf4a3a000)
libogg.so.0 => /usr/lib/i386-linux-gnu/libogg.so.0 (0xf4a31000)
libvorbis.so.0 => /usr/lib/i386-linux-gnu/libvorbis.so.0 (0xf4a04000)
joey@Chet:~$
After sudo apt-get install libstdc++6
libstdc++6 is already the newest version.
The following packages were automatically installed and are no longer required:
fonts-horai-umefont fonts-unfonts-core gnome-exe-thumbnailer libcapi20-3 libcapi20-3:i386 libexif12:i386 libgd3:i386 libgif4:i386 libgphoto2-6:i386 libgphoto2-port12:i386 libgstreamer-plugins-base0.10-0:i386 libgstreamer0.10-0:i386 libice6:i386 libieee1284-3:i386 libltdl7:i386 libodbc1 liborc-0.4-0:i386 libosmesa6 libosmesa6:i386 libp11-kit-gnome-keyring:i386 libsane:i386 libsm6:i386 libusb-1.0-0:i386 libv4l-0:i386 libv4lconvert0:i386 libvpx2:i386 libxpm4:i386 libxslt1.1:i386 libxt6:i386 odbcinst odbcinst1debian2 p11-kit-modules:i386 unixodbc Use 'apt-get autoremove' to remove them. 0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
