I would like to uninstall Nitroshare from ubuntu 15.10. But after installation the program does not show up as installed program in the software center.
How to uninstall Nitroshare?
If you installed NitroShare via PPA or by installing one of the binary packages from the website, you can remove it using the following terminal command:
sudo apt-get remove nitroshare
If you built NitroShare from source, you will need to manually remove the files. Here's a list of the files to remove ($PREFIX is usually /usr or /usr/local):
$PREFIX/bin/nitroshare
$PREFIX/share/applications/nitroshare.desktop
$PREFIX/share/icons/gnome/24x24/apps/nitroshare-indicator.png
$PREFIX/share/icons/hicolor/scalable/apps/nitroshare.svg
$PREFIX/share/icons/hicolor/scalable/apps/nitroshare-indicator.svg
$PREFIX/share/icons/ubuntu-mono-dark/apps/22/nitroshare-indicator.png
$PREFIX/share/icons/ubuntu-mono-dark/apps/24/nitroshare-indicator.svg
$PREFIX/share/icons/ubuntu-mono-light/apps/22/nitroshare-indicator.png
$PREFIX/share/icons/ubuntu-mono-light/apps/24/nitroshare-indicator.svg
