I created a live system using Systemback in "computer A" and installed it with no problems in "computer B" but the only annoyance is that HAL gave my network interface cards the names eth1 to the Wired Interface and wlan2 to the Wireless Interface in "computer B". I have a lot of scripts and aliases hardcoded (BAD PRACTICE, I know).
Systemback created an exact copy of my configuration in "computer A" so this is why in "computer B" It couldn't hand out eth0 and wlan0 because these two names were already in use.
I know how to and can easily replace the problematic text with sed in all the scripts and aliases but i'd like to know how can I change these names given by HAL.
Jeremy Kerr
  • 27,829
zehnner
  • 388
Here's what happened: when you did the original setup on System A, your machine reserved the names eth0 and wlan0 for the particular devices you had in that machine.
When you moved to System B, the new network devices were found, and (as you mention) renamed to not conflict with those earlier definitions of eth0 and wlan0.
That original mapping of names is kept in:
/etc/udev/rules.d/70-persistent-net.rules
If you delete that file, your next boot will start up with no "reserved" names for those network devices in System A, and you'll get eth0 and wlan0 back.
If they're discovered in a different order (say, if you had two ethX devices in System B, and you expect them in a different order), you can edit the NAME= defintions in that file to suit your own naming requirements.
Jeremy Kerr
  • 27,829
