G'Day; I have Ubuntu 15.10 on one partition and Ubuntu Mate 15.10 on another partition, is there some way I can choose which grub boot loader is used, I want to use the Mate bootloader..
Asked
Active
Viewed 875 times
Serg is (sort of) correct. If the output of cat /etc/fstab includes a line that mentions /boot/efi, you're booted in EFI mode (proceed to EFI). If it says something like "not found", or just outputs nothing, you're not in EFI mode. (proceed to BIOS)
EFI
This will be a list of commands to run, run them from top to bottom:
sudo grub-install --efi-directory=/boot/efi --bootloader-id=ubuntumate --target=x86_64-efi --recheck --debug
sudo grub-mkconfig -o /boot/efi/EFI/ubuntumate/grub.cfg
(I don't know if boot/efi/EFI/ubuntumate will be the path where GRUB is installed, you may want to do sudo ls /boot/efi/EFI and figure out if it's in GRUB or ubuntumate)
BIOS
Do sudo grub-install /dev/sda
FireFaced
- 187
