When i go into hibernation and resume then look at the result of running uptime , i note that the the hibernation duration is also included.
in pm-hibernate man pages. it states that: "During hibernate the system is fully powered off," .
shouldn't uptime be resetting to zero if the 'the system is fully powered off' or pausing because the system is hibernated hibernated, or is this a bug?
Asked
Active
Viewed 2,340 times
danleyb2
- 183
- suspend/hibernate are not considered "off". The last "wake up time" is stored in
/var/log/pm-suspend.log.
- now that would be odd. How would one then know what the actual uptime is?
or is this a bug?
Uptime is the time since last (re)boot. Basically the system stores at boot time what the time is and "now" -/- that time is the uptime. So in that regard: no, not a bug. The command predates notebooks and hibernate/suspend so maybe if you create a feature request someone decides it is a good feature to have. It probably is a very easy addition:just update the time stored on disk. And I can not imagine it is a lot more than adding a call to the hibernation/suspend script. But it will also be difficult to get it happen :)
Rinzwind
- 309,379
