whenever i want to install wine it five me error even some other software too give me error i try to install it from terminal
my command was this = sudo apt-get install wine
 unity-control-center : Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
                        Depends: libcheese7 (>= 3.0.1) but it is not going to be installed
 wine : Depends: wine1.6 but it is not going to be installed or
                 wine1.7 but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by he
when i try to install it from software center. it give me following error.
This error could be caused by required additional software packages which are missing or not installable. Furthermore there could be a conflict between software packages which are not allowed to be installed at the same time.
in detailt
unity-control-center: Depends: libpulse-mainloop-glib0 (>= 1:0.99.1) but 1:4.0-0ubuntu11.1 is to be installed
                      Depends: libpulse0 (>= 1:0.99.1) but 1:4.0-0ubuntu11.1 is to be installed
                      Depends: libxi6 (>= 2:1.2.99.4) but 2:1.7.1.901-1ubuntu1.1 is to be installed
wine1.6: Depends: wine1.6-amd64 (= 1:1.6.2-0ubuntu4) but 1:1.6.2-0ubuntu4 is to be installed
         Depends: wine1.6-i386 (= 1:1.6.2-0ubuntu4) but it is a virtual package
im so frustrated because of this. i really want to un install. i try to search the same problem but no solution worked for me can anyone help me please.
Nothing Seems to be wrong with your package system
you may need to download and install new updates open up a terminal and type in
sudo apt-get update && sudo apt-get dist-upgrade -y
now try to install wine1.6 open up a terminal and type in
sudo apt-get install wine1.6
if that still dose not work open up /var/log/dist-upgrade/apt.log with a text editer.
sudo nano /var/log/dist-upgrade/apt.log
Locate any "broken" packages and remove them with sudo apt-get remove <package> if you have trouble locating the broken packages in the apt.log copy its text and add it to you're post by editing it.
Ok you have broken packages remove them by typing in this command.
sudo apt-get remove aptitude:i386 brasero wine
Then run
then install wine
Neil
  • 4,585
Try this:
Open the terminal and try the following commands:
sudo dpkg --configure -a
sudo apt-get install -f
sudo apt-get update
then Go to ubuntu software center ==> Edit ==> Software Sources ==> Download From ==> Select main server
uninstall wine :
sudo apt-get remove wine
rm -rf ~/.wine
After that restart your computer go to software center and type wine and install it enter image description here
plastic
