I am trying to install msitools from http://ftp.gnome.org/pub/GNOME/sources/msitools/0.94/. When I do a ./configure, I get the following error:
configure: error: Package requirements (libgsf-1) were not met:
No package 'libgsf-1' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables GSF_CFLAGS
and GSF_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
I believe that libgsf-1 is not installed, so when I do sudo apt-get install libgsf-1, I get the below error:
Reading package lists... Done
Building dependency tree
Package libgsf-1 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  libgsf-bin:i386 libgsf-bin libgsf-1-common
E: Package 'libgsf-1' has no installation candidate
Please help me resolve this.
am28
try installing libgsf-1-dev instead:
sudo apt-get install  libgsf-1-dev
How did I know to do this? Ok, I totaly belived you when you said libgsf wasnt installed. and libgsf-1 just doesnt sound like a package name to me, if it were, its name would be libgsf-1-something. anyhow, I then searched the repos for the package:
$ sudo apt-cache search libgsf-1
libgsf-1-114 - Structured File Library - runtime version
libgsf-1-114-dbg - Structured File Library - debugging files (basic version)
libgsf-1-common - Structured File Library - common files
libgsf-1-dev - Structured File Library - development files
if you noticed, when you ran sudo apt-get install libgsf-1-dev you probably saw libgsf-1-114 libgsf-1-common libgsf-1-dev listed in the set of files installed. Do you need the dev version? IDK, I assume so.
j0h
  • 15,365
