I'm getting trouble by the error:
click-system-hooks.service couldn't start.
Errors were encountered while processing:  /var/cache/apt/archives/click_0.4.38.5ubuntu0.2_amd64.deb
It's also showing this message:
How to solve it?
I have tried:
$ sudo dpkg --configure -a
$ sudo apt-get install systemd
And the output is:
Reading package lists... Done
Building dependency tree
systemd is already the newest version.
You might want to run 'apt-get -f install' to correct these:
click : Depends: python3-click (= 0.4.38.5) but 0.4.38.5ubuntu0.2 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I tried running sudo apt-get -f install, as suggested, and the output is:
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
at bzr-builddeb debian-archive-keyring devscripts distro-info
distro-info-data dput libdistro-info-perl
libexporter-lite-perl libio-stringy-perl
libparse-debcontrol-perl libtie-ixhash-perl libxdelta2
pbuilder pbzip2 pristine-tar pybootchartgui python-debianbts
python-defusedxml python-distro-info python-lzma
python-reportbug python-requests python-soappy
python-ubuntutools python-wstools quilt reportbug
ubuntu-dev-tools xdelta
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
click
Suggested packages:
ubuntu-app-launch-tools upstart-app-launch-tools
The following packages will be upgraded:
click
1 upgraded, 0 newly installed, 0 to remove and 38 not upgraded.
Need to get 0 B/14.4 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 560681 files and directories currently installed.)
Preparing to unpack .../click_0.4.38.5ubuntu0.2_amd64.deb ...
Please enter passphrase for disk Samsung_SSD_850_EVO_120GB (var)! ********************
Please enter passphrase for disk Samsung_SSD_850_EVO_120GB (cryptswap1)!
Broadcast message from root@....... (Fri 2015-10-23 23:03:00 ICT):
Password entry required for 'Please enter passphrase for disk Samsung_SSD_850_EVO_120GB (cryptswap1)!' (PID 11194).
Please enter password with the systemd-tty-ask-password-agent tool!
Traceback (most recent call last):
File "/usr/bin/click", line 31, in <module
    from click import commands
ImportError: cannot import name 'commands'
dpkg: warning: subprocess old pre-removal script returned error exit status 1
dpkg: trying script from the new package instead ...
dpkg: error processing archive /var/cache/apt/archives/click_0.4.38.5ubuntu0.2_amd64.deb (--unpack):
subprocess new pre-removal script returned error exit status 1
Broadcast message from root@........(Fri 2015-10-23 23:03:05 ICT):
Password entry required for 'Please enter passphrase for disk Samsung_SSD_850_EVO_120GB (var)!' (PID 13188).
Broadcast message from root@......... (Fri 2015-10-23 23:03:05 ICT):
Password entry required for 'Please enter passphrase for disk Samsung_SSD_850_EVO_120GB (cryptswap1)!' (PID 13187).
Please enter passphrase for disk Samsung_SSD_850_EVO_120GB (cryptswap1)! Job for click-system-hooks.service failed. See "systemctl status click-system-hooks.service" and "journalctl -xe" for details.
Broadcast message from root@........... (Fri 2015-10-23 23:03:10 ICT):
evergreen
  • 995
It looks that don't have systemd, but installer false detects it installed. It is a known bug in Ubunutu #1448623. Make sure, the systemd is installed
dpkg --configure -a
Then purge click, as suggested in this comment by weiqi_chen
sudo pip3 uninstall click
sudo apt-get purge click
yurikoles
  • 1,253
Your click problem
click for Vivid has the version 0.4.38.5ubuntu0.2 and needs exactly the same python3-click version. Both are in the repositories.
  1. Remove the DEB file
    sudo apt-get clean
  2. Update the package information
    sudo apt-get update
  3. Reinstall click
    sudo apt-get install --reinstall click
Your ttf-mscorefonts-installer
  1. Install the package ttf-mscorefonts-installer, we need some things from the package ater
    sudo apt-get install --reinstall ttf-mscorefonts-installer
  2. Download and install the fonts
    TMP=$(mktemp -d)
    cd "$TMP"
    awk '/Url/ {system("wget "$2)}' /usr/share/package-data-downloads/ttf-mscorefonts-installer
    sudo /usr/lib/msttcorefonts/update-ms-fonts "$TMP"/*
  3. Avoid future error message
    sudo touch /var/lib/update-notifier/package-data-downloads/ttf-mscorefonts-installer
  4. Housekeeping
    cd ..
    rm -r "$TMP"
A.B.
  • 92,125
