i want to place a script file on other machine root . here is my terminal command
scp /var/www/html/script.sh root@192.168.1.7:script.sh
it asks for root password. i enter correct root password but it says
Permission denied, please try again.
Can anybody help?
muru
  • 207,228
Sony Khan
  • 111
By default openssh will denied any root login attempt. However, this can be allowed by modifying /etc/ssh/sshd_config on the server side.
Make sure this line sets to yes and no commented out:
PermitRootLogin yes
And then reload your sshd.
However, above setup is not a good security practice. Instead use pubkey login.
the config line should be:
PermitRootLogin without-password.
  1. On source machine genereate key, follow the wizard:
    ssh-keygen -t rsa
  2. Above command will create .ssh/id_rsa.pub and .ssh/id_rsa containing public and private key pair. You need to copy .ssh/id_rsa.pub content into the destination machine /root/.ssh/authorized_keys. Make the directory and file if its not exist and make sure the ownership of the authorized_keys is 600.
  3. Now try scp attempt, it will asks for password that you have entered in step 1.
Presuming you have have password-less sudo access, the following should work:
$ echo "My test file" > test
$ scp test sudo_user@example.com:/tmp/
test
$ ssh sudo_user@example.com "sudo mv /tmp/test /"
$ ssh sudo_user@example.com "cat /test"
My test file
  1. Create a test file.
  2. Copy file to temp directory.
  3. Move file to root directory.
  4. Test that file is on the root directory.
Batandwa
  • 153
