I installed ubuntu 14.04 on an acer Aspire-E3-112. Now i want to install it again because nothing works at the moment but ... How to install Ubuntu or a nother linux by using this ubuntu? And I am a newby to the comman line I dont have a live USB and can't use cd
Asked
Active
Viewed 106 times
You can download the distribution that you want here
http://www.ubuntu.com/download/desktop
Then from your desktop press the superuser button (the windows button on your keyboard) and search for startup disk creator. Plug in a blank USB stick with at least 2G of free memory and launch the startup disk creator. Select the distribution that you downloaded. Make sure that your bios is set to boot from a usb drive (which you can access by pressing a certain key such as F2 or esc while the computer boots) and reboot the computer. If your BIOS successfully boots from the USB drive you will see an option to install ubuntu. Select that option and follow the prompts.
William
- 103
