10
 vlc : Depends: vlc-nox (= 2.1.4+git20150226+r54594+19+11~ubuntu14.04.1) but it is not going to be installed
       Depends: libsdl-image1.2 (>= 1.2.10) but it is not installable
       Depends: libtar0 but it is not installable
       Depends: libva-x11-1 (> 1.3.0~) but 1.0.15-4 is to be installed
       Depends: libva1 (> 1.3.0~) but 1.0.15-4 is to be installed
       Depends: libvlccore7 (>= 2.1.0) but it is not going to be installed
       Recommends: vlc-plugin-notify (= 2.1.4+git20150226+r54594+19+11~ubuntu14.04.1) but it is not going to be installed
       Recommends: vlc-plugin-pulse (= 2.1.4+git20150226+r54594+19+11~ubuntu14.04.1) but it is not going to be installed
I tried
  1. sudo apt-get install -f
  2. sudo apt-get update
  3. sudo apt-get upgrade
  4. sudo apt-get purge vlc vlc-nox libsdl-image1.2 libtar0 libva-x11-1 libva1 libvlccore7 vlc-plugin-notify vlc-plugin-pulse
But the error remains. VLC is not the only thing. many other packages I try to install gave me similar dependency errors which I finally gave up installing.
I have been using Ubuntu for a while now. I just don't understand why this happens every now and then. Please help ...
EDIT:
Output of apt-cache policy vlc vlc-nox libsdl-image1.2 libtar0 libva-x11-1 libva1 libvlccore7
vlc:
  Installed: (none)
  Candidate: 2.1.4+git20150226+r54594+19+11~ubuntu14.04.1
  Version table:
     2.1.4+git20150226+r54594+19+11~ubuntu14.04.1 0
        500 http://ppa.launchpad.net/videolan/stable-daily/ubuntu/ trusty/main i386 Packages
vlc-nox:
  Installed: (none)
  Version table:
libsdl-image1.2:
  Installed: (none)
  Candidate: (none)
  Version table:
libtar0:
  Installed: (none)
  Candidate: (none)
  Version table:
libva-x11-1:
  Installed: (none)
  Candidate: (none)
  Version table:
libva1:
  Installed: (none)
  Candidate: (none)
  Version table:
libvlccore7:
  Installed: (none)
  Version table:
As you can see in the output of apt-cache policy … there are some packages without an installation candidate and that should not be the case. Therefore a quick search here shows, that all packages are available in the universe repository, e.g. for the package libsdl-image1.2.
Add the repository:
sudo apt-add-repository universe
sudo apt-get update
sudo apt-get install vlc
cl-netbox
  • 31,491
A.B.
  • 92,125
