I want to read the manpage for the application cutechess, however I do not want to install it, so is there any way to get and read a manpage for a package without installing it? That is through the command-line and not a browser (a Terminal browser such as lynx does not count). This method should work for all packages and not be specific to cutechess though. I am running Ubuntu GNOME 15.04.
Asked
Active
Viewed 168 times
A manpage for cutechess can be found here This is the results of a simple search for manpage and cutechess
The script below (taken from here) can be used to read manpages from the internet, in a terminal window. Usage is dman <topic>, if the script is saved as dman
#!/bin/sh -e
# This is the Ubuntu manpage repository generator and interface.
# Copyright (C) 2008 Canonical Ltd.
# This code was originally written by Dustin Kirkland <kirkland@ubuntu.com>,
# based on a framework by Kees Cook <kees@ubuntu.com>.
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program. If not, see <http://www.gnu.org/licenses/>.
# On Debian-based systems, the complete text of the GNU General Public
# License can be found in /usr/share/common-licenses/GPL-3
. /etc/lsb-release
while true; do
case "$1" in
--release)
DISTRIB_CODENAME="$2"
shift 2
break
esac
done
PAGE=`echo "$@" | awk '{print $NF}'`
MAN_ARGS=`echo "$@" | sed "s/\$PAGE$//"`
# Mirror support of man's languages
if [ ! -z "$LANG" ]; then
LOCALE="$LANG"
fi
if [ ! -z "$LC_MESSAGES" ]; then
LOCALE="$LC_MESSAGES"
fi
if echo $LOCALE | grep -q "^en"; then
LOCALE=""
fi
URL="http://manpages.ubuntu.com/manpages.gz/"
mandir=`mktemp -d dman.XXXXXX`
trap "rm -rf $mandir" EXIT HUP INT QUIT TERM
for i in `seq 1 9`; do
man="$mandir/$i"
if wget -O "$man" "$URL/$DISTRIB_CODENAME/$LOCALE/man$i/$PAGE.$i.gz" 2>/dev/null; then
man $MAN_ARGS -l "$man" || true
fi
rm -f "$man"
done
You can also download the script with:
wget http://manpages.ubuntu.com/dman
terdon
- 104,119
Charles Green
- 21,859
The dman script which should allow you to browse the Ubuntu man pages found at http://manpages.ubuntu.com/dman can be fetched via the command line using wget:
Make sure the working dman is in your path and executable, and you should be able to call it like any other command line utility.
Arronical
- 20,241
All of Ubuntu's man pages, for all currently supported releases, are available through Ubuntu's online man pages
waltinator
- 37,856
