Ubuntu randomlly decided to install this huge batch of updates today and I let it.
It froze however midway. I gave it an extra hour with no progress at all so I killed it and forced a hard restart.
Now whenever I try to do anything using DPKG's such as installing a new program, I get the error that
dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
Not a problems so I run it.....but then it hangs for a long time every time it runs into this part:
I've already tried that --configure -a command and that hangs as well.
Generating grub configuration file ...
Found initrd image: /boot/initrd.img-3.19.0-15-generic
dpkg: error processing package linux-generic (--configure):
 dependency problems - leaving unconfigured
 linux-image-3.19.0-31-generic
 linux-image-extra-3.19.0-31-generic
 linux-image-generic
 linux-generic
I've tried commands like sudo-apt-get install -f, the autoremove packages command and others but none seem to work?
EDIT: I've now gotten past that to where sudo apt-get update will work.. and it won't hang anymore...but no programs can install. Ubuntu Software Center just keeps on saying Applying Changes.....
EDIT: SOLVED! https://www.swiftbyte.com/articles/linux/grub-configuration-hangs-during-kernel-update-on-ubuntu-running-in-hyper-v
It has to do with stuff I did on my other hard drives that aren't Linux related.
bobo06
  • 69
