my problem is that, my laptop is entirely new and it has
    sensors
    acpitz-virtual-0
    Adapter: Virtual device
    temp1:        +74.0°C  (crit = +99.0°C)
    temp2:        +74.0°C
    coretemp-isa-0000
    Adapter: ISA adapter
    Physical id 0:  +73.0°C  (high = +84.0°C, crit = +100.0°C)
    Core 0:         +73.0°C  (high = +84.0°C, crit = +100.0°C)
    Core 1:         +69.0°C  (high = +84.0°C, crit = +100.0°C)
    Core 2:         +72.0°C  (high = +84.0°C, crit = +100.0°C)
    Core 3:         +72.0°C  (high = +84.0°C, crit = +100.0°C)
too high temperature.
    :~$ lspci -k | grep -EA2 'VGA|3D'
    00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core
    Processor Integrated Graphics Controller (rev 06)
            Subsystem: Lenovo Device 3809
            Kernel driver in use: i915
    01:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 840M] (rev a2)
    07:00.0 Network controller: Qualcomm Atheros QCA9565 / AR9565
    Wireless Network Adapter (rev 01)
Does anybody have the same problem as me? According to the specifications it ought to have 36 degrees.
It's a bit better.
temp1:        +58.0°C  (crit = +99.0°C)
temp2:        +58.0°C
coretemp-isa-0000
Physical id 0:  +57.0°C  (high = +84.0°C, crit = +100.0°C)
Core 0:         +54.0°C  (high = +84.0°C, crit = +100.0°C)
Core 1:         +53.0°C  (high = +84.0°C, crit = +100.0°C)
Core 2:         +56.0°C  (high = +84.0°C, crit = +100.0°C)
Core 3:         +57.0°C  (high = +84.0°C, crit = +100.0°C)
It is not almost perfect. After using my laptop for several hours it is still bad. I just use mozilla, okular and libre office.
    temp2:        +74.0°C
    coretemp-isa-0000
    Physical id 0:  +76.0°C  (high = +84.0°C, crit = +100.0°C)
    Core 0:         +69.0°C  (high = +84.0°C, crit = +100.0°C)
    Core 2:         +73.0°C  (high = +84.0°C, crit = +100.0°C)
    Core 3:         +76.0°C  (high = +84.0°C, crit = +100.0°C)
    thinkpad-isa-0000
    fan1:           0 RPM
Seth
  • 59,332
Install the Nvidia proprietary driver this way:
sudo apt-get install nvidia-346 nvidia-prime
and reboot.
Your both graphics adapters consume power. that causes overheating.
And your discrete adapter does not work without the driver.
You can switch to the powersave Intel adapter by:
sudo prime-select intel
then log off and log on.
Pilot6
  • 92,041
