13
On the mac there is a feature which allows you to get your computer to verbally announce the time on the hour, is there something similar on Ubuntu? That is is there a package which already does this or do I need to configure something like say to read out the time on the hour? And if so then how do I do that? I am running Ubuntu GNOME 15.04 with GNOME 3.16.
You could use your crontab
  1. Create a little script
     mkdir -p ~/bin
     nano ~/bin/say_hour
add the code below
    #!/usr/bin/env bash
    my_date=$(date +'%H:%M:%S')
    padsp espeak "$my_date"
and set executable rights
    chmod +x ~/bin/say_hour
  1. Edit your crontab via
     crontab -e
and add the configuration below
    0 * * * * bin/say_hour
You can replace the espeak line with one of the possibilities below
sudo apt-get install espeak
espeak $(date +"%H:%M:%S")
espeak $(date +%T)
Adjust speed with -s, in words per minute, default is 160
espeak -s 10 $(date +"%H:%M:%S")
or
sudo apt-get install festival
date +"%H:%M:%S" | festival --tts
date +%T | festival --tts
or
sudo apt-get install speech-dispatcher
spd-say $(date +"%H:%M:%S")
spd-say $(date +%T)
Adjust speed with (-100 .. 0 .. 100)
spd-say -r -50 $(date +%T)
  • %I – hour (01..12) format
  • %H – hour in (00..23) format
  • %M – minute (00..59)
  • %S – second (00..60)
  • %P – period (AM/PM)
  • %THH:MM:SS in 24 Format
More options via man date, man espeak, man festival and man spd-say
A.B.
  • 92,125
This gives you the time in speech (thanks to kos for providing better syntax) :
First install say , which is found in gnustep-gui-runtime:
sudo apt-get install gnustep-gui-runtime
Then run it.
24-hour mode:
say "$(date +%R)"
12-hour mode
say "$(date +%I:%M%p)"
Promille
  • 508
