I decided to update OS to 14.04. While downloading packages i noticed download totally stopped and had to interrupt it, and that happened several times. Then it started installing everything and it froze again. I waited for few h and it didnt changed anything. So i restarted pc and problem happened(knew that i shouldn't do it). Now when login to my account, after 1 second it just logs out.Only thing that i can do is login as guest user, but as a guest i can't use sudo in terminal.Guys, please tell me what should i do,i'm not so fammiliar with linux and i need to change os to windows.Do i need to reinstall linux first and how ?I need help asap,thanks.
Nicola123
Try this:
Switch on your computer.
Press and hold the Shift key, which will bring up the Grub menu.
Select the line which starts with Advanced options.
Select the line ending with (recovery mode)
Press Return and your computer will begin the boot process.
Your computer should display a menu with a number of options.
One of the options will be Check all file systems.
Press Return with this option highlighted.
Other of the options will be Enable networking.
Other of the options will be Drop to root shell prompt.
Your computer should boot in a terminal, so enter the commands:
mount -o remount,rw /
mount --all
dpkg --configure -a
apt-get autoremove
apt-get update
apt-get dist-upgrade
apt-get -f install
apt-get -m install
apt-get clean
reboot
kyodake
  • 17,808
