The same question was asked on SU, and glallen wrote a Python script for it since tree doesn't have the option:
Usage: tree.py -f [file limit] <directory>
If a number is specified for -f [file limit] then ... <additional files> is printed and the other files are skipped. Additional
directories should not be skipped however. If the file limit is set to
10000 (default) this acts as no limit
#! /usr/bin/env python
# tree.py
# Written by Doug Dahms
# modified by glallen @ StackExchange
# Prints the tree structure for the path specified on the command line
from os import listdir, sep
from os.path import abspath, basename, isdir
from sys import argv
def tree(dir, padding, print_files=False, limit=10000):
print padding[:-1] + '+-' + basename(abspath(dir)) + '/'
padding = padding + ' '
limit = int(limit)
files = []
if print_files:
files = listdir(dir)
else:
files = [x for x in listdir(dir) if isdir(dir + sep + x)]
count = 0
for file in files:
count += 1
path = dir + sep + file
if isdir(path):
print padding + '|'
if count == len(files):
tree(path, padding + ' ', print_files, limit)
else:
tree(path, padding + '|', print_files, limit)
else:
if limit == 10000:
print padding + '|'
print padding + '+-' + file
continue
elif limit == 0:
print padding + '|'
print padding + '+-' + '... <additional files>'
limit -= 1
elif limit <= 0:
continue
else:
print padding + '|'
limit -= 1
def usage():
return '''Usage: %s [-f] [file-listing-limit(int)] <PATH>
Print tree structure of path specified.
Options:
-f Print files as well as directories
-f [limit] Print files as well as directories up to number limit
PATH Path to process''' % basename(argv[0])
def main():
if len(argv) == 1:
print usage()
elif len(argv) == 2:
# print just directories
path = argv[1]
if isdir(path):
tree(path, ' ')
else:
print 'ERROR: '' + path + '' is not a directory'
elif len(argv) == 3 and argv[1] == '-f':
# print directories and files
path = argv[2]
if isdir(path):
tree(path, ' ', True)
else:
elif len(argv) == 4 and argv[1] == '-f':
# print directories and files up to max
path = argv[3]
if isdir(path):
tree(path, ' ', True, argv[2])
else:
else:
print usage()
if name == 'main':
main()
When run, it should produce output similar to:
user@host /usr/share/doc $ python /tmp/recipe-217212-1.py -f 2 . | head -n 40
+-doc/
+-libgnuradio-fft3.7.2.1/
| +-copyright
| +-changelog.Debian.gz
+-libqt4-script/
| +-LGPL_EXCEPTION.txt
| +-copyright
| +-... <additional files>
+-xscreensaver-gl/
| +-copyright
