I'm new to Ubuntu and have a question. My company uses a custom certificate which is put into the certificate chain. Having this, Firefox always asks me to add an exception and also on the terminal I can't use wget for https addresses for example.
Is there any way to make Ubuntu accept / learn to use our company's certificate? I already tried to export the certificate from Firefox to a .crt file, copy it to /usr/local/share/ca-certificates and call update-ca-certificates, but with no success.
Any idea? If you need further information, let me know. Thanks in advance.
Thanks for the comment regarding FF. Anyhow I need to solve this for the command line interface too. By the way, this is the error I get in the command line. 192.168.1.8:1357 is my “local” proxy, which communicates with the company’s Windows Proxy.
ubuntu-dev:~/Documents/certificates$ wget https://repo1.maven.org/maven2/org/postgresql/postgresql/9.4-1204-jdbc42/postgresql-9.4-1204-jdbc42.pom
--2015-10-14 16:54:44--  https://repo1.maven.org/maven2/org/postgresql/postgresql/9.4-1204-jdbc42/postgresql-9.4-1204-jdbc42.pom
Connecting to 192.168.1.8:1357... connected.
ERROR: cannot verify repo1.maven.org's certificate, issued by ‘CN=MYCOMP,OU=Departx,O=MYCOMP,C=AT’:
Unable to locally verify the issuer's authority.
To connect to repo1.maven.org insecurely, use `--no-check-certificate'.
Kenshin
