libgluezilla doesn't seem to be available anymore. This breaks a few Mono apps on Ubuntu.
Where can I get it? libmono-webbrowser4.0-cil is installed, but it doesn't install libgluezilla.
Climax
  • 171
The latest version was for Lucid, but you can install the package also in Vivid with some aditionally packages.
  • Download the Lucid version of libgluezilla_2.4.3-2
    • 32-bit
      cd; wget http://security.ubuntu.com/ubuntu/pool/main/g/gluezilla/libgluezilla_2.4.3-2_i386.deb
      OR
    • 64-bit
      cd; wget http://security.ubuntu.com/ubuntu/pool/main/g/gluezilla/libgluezilla_2.4.3-2_amd64.deb
  • Download xulrunner-1.9.2
    • 32-bit
      cd; wget http://security.ubuntu.com/ubuntu/pool/main/x/xulrunner-1.9.2/xulrunner-1.9.2_1.9.2.28+build1+nobinonly-0ubuntu0.10.04.1_i386.deb
      OR
    • 64-bit
      cd; wget http://security.ubuntu.com/ubuntu/pool/main/x/xulrunner-1.9.2/xulrunner-1.9.2_1.9.2.28+build1+nobinonly-0ubuntu0.10.04.1_amd64.deb
  • Download libhunspell-1.2-0
    • 32-bit
      cd; wget http://security.ubuntu.com/ubuntu/pool/main/h/hunspell/libhunspell-1.2-0_1.2.8-6ubuntu1_i386.deb
      OR
    • 64-bit
      cd; wget http://security.ubuntu.com/ubuntu/pool/main/h/hunspell/libhunspell-1.2-0_1.2.8-6ubuntu1_amd64.deb
  • Install dependencies available in the repositories (perhaps more depends on your current installation)
    sudo apt-get install libnspr4-0d libidl0 libnss3-1d
  • Install
    • 32-bit
      sudo dpkg -i libgluezilla_2.4.3-2_i386.deb xulrunner-1.9.2_1.9.2.28+build1+nobinonly-0ubuntu0.10.04.1_i386.deb libhunspell-1.2-0_1.2.8-6ubuntu1_i386.deb
      OR
    • 64-bit
      sudo dpkg -i libgluezilla_2.4.3-2_amd64.deb xulrunner-1.9.2_1.9.2.28+build1+nobinonly-0ubuntu0.10.04.1_amd64.deb libhunspell-1.2-0_1.2.8-6ubuntu1_amd64.deb
Tested in my Vivid system
% lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 15.04
Release:    15.04
Codename:   vivid
% apt-cache policy libgluezilla
libgluezilla:
  Installed: 2.4.3-2
  Candidate: 2.4.3-2
  Version table:
 *** 2.4.3-2 0
        100 /var/lib/dpkg/status
A.B.
  • 92,125
The solution provided by A.B. works fine for 16.04.2 but note that when installing the libidl0 using apt-get, it will require libidl-2-0. A solution to install libidl0 on Ubuntu 16.04 is here: Unable to install Kompozer in Ubuntu 16.04 After libidl0 is installed. Follow A.B.'s steps and it works!!
For 14.04, it seems it does not work as the xulrunner cannot be installed. Still figuring out how it can be done correctly.
$ lsb_release -a
Description:    Ubuntu 16.04.2 LTS
Release:    16.04
Codename:   xenial
$ apt-cache policy libgluezillalibgluezilla:
  Installed: 2.4.3-2
  Candidate: 2.4.3-2
  Version table:
 *** 2.4.3-2 100
Hao
