I have installed ubuntu server 64-bit and I want to install gnome 3 or KDE. What dependencies must be installed? Please specify all steps.
The instructions are same as converting a normal server install to a desktop one. Gnome 3 is the default in 11.10, so you can just run the following:
sudo apt-get install ubuntu-desktop
and be done with it. If you want GNOME shell you'll need to install that too:
Another Question reports issues with installing ubuntu-desktop on a server in 11.10.
Using sudo apt-get install ubuntu-desktop gets you unity.
If you don't want unity, then install either gnome, gnome-shell, or gnome-session-fallback. These get you the full GNOME3 desktop, a lighter weight version of GNOME, or a look-alike GNOME2 respectively. The last one gives you versions with and without effects. Each one of those gnome options is based on gnome 3, no matter what they look like. If you want the real gnome2, then install Mate. It is a fork of gnome2 by Linux Mint. If you want a classic gnome2 look, but based on gnome3 code that isn't gnome-session-fallback, you can also install Cinnamon from Linux Mint .
- 6,940
- 31
You can use :
sudo aptitude install --without-install-recommends ubuntu-desktop
or
sudo aptitude install --without-recommends ubuntu-desktop
for smaller package to download.
- 17,872
I found this helpful:
sudo apt-get install xorg gnome-core gnome-system-tools gnome-app-install
- 111
