Hello and thanks in advance to anyone that tries to answer this tough one.
This is different from just installing the Nvidia drivers. This is a hosed system caused by updating my laptop while xorg-edgers ppa was in my repository list. This created a system with (in my case) the symptoms below. Un-installing and re-installing after purging the xorg-edgers ppa does not fix the issue.
I have an Asus N56J laptop with Ubuntu 14.04. It has an Nvidia 840M GPU. When I first built the machine I used the directions in http://www.binarytides.com/install-nvidia-drivers-ubuntu-14-04/ to add drivers for the nvidia GPU. All went well and everything ran perfectly. However, I did use the PPA from xorg-edgers and left that ppa in my list of repositories.
Yesterday, I got an Ubuntu update message so when ahead and did the update. The Kernel was updated to 3.16.0-50 and I am now showing a 14.04.3 release. But this update broke the system in a number of ways that make the system unusable.
The symptoms so far are:
  1. Firefox will become unresponsive if you go to certain web pages (maybe ones with video?). The screen greys out and never comes back.
  2. The backlit keyboard no longer lights up with the f3 or f4 buttons as it used to
  3. The mouse pointer goes away after you have been logged in for 30 seconds. If you wait about 1 minute, it comes back.
  4. Cntl-Alt-T no longer brings up a terminal window unless you have already started a Terminal window via clicking an Icon.
  5. The system will no longer shut down. You have to hard power it off.
  6. The system will no longer suspend when you close the screen.
I suspected that having the xorg-edgers repository was my issue as they have a warning saying not to upgrade your system without doing a ppa-purge of their repository. I did not do an upgrade of course but I thought it could be related. I have since did a ppa-purge of this repository and removed the nvdia drivers. This had no effect on my symptoms.
I noticed that this latest update did update my nvidia drivers (well libcuda1-340:amd64 (340.76-0ubuntu1~xedgers14.04.4, 340.93-0ubuntu0.0.1),nvidia-340:amd64 (340.76-0ubuntu1~xedgers14.04.4, 340.93-0ubuntu0.0.1) and nvidia-opencl-icd-340:amd64 (340.76-0ubuntu1~xedgers14.04.4, 340.93-0ubuntu0.0.1)) so I thought maybe this was the issue.
Any ideas on what I can try to fix this? I know I can re-install but would like to avoid that if possible.
Thanks again.
UPDATE:
I ended up reloading using the directions at: http://ubuntuforums.org/showthread.php?t=2057342
That worked well although I had to restore /var/www/html directory and files. That got whacked. Interesting, mysql databases remained though even though the files are in /var.
I have a working system again (yeah!). I also reloaded the nvidia-340 drivers from the official Ubuntu repository and they are working well. There is probably an easier way to fix this if I could have identified the offending package (maybe from xorg-edgers ?).
Love this laptop and Ubuntu running on it. This was the first time something like this happened but it was a learning experience. Thanks again for the help.
Yet another Update:
Somehow my machine has again reverted back to the same broken state. I am not sure how as I don't recall doing any updates. I tried undoing minor configuration changes in /etc/default/grub (GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=") as well as some changes to alsa to get the subwolfer working. Still it remains broken. I believe another rebuild is in my future. Its odd, as after the rebuild, everything works as it should. Then something suddenly breaks. If I get this solved, Ill update it here.
Bottom line is my issue has nothing to do with the xorg-edgers repository.
Update 3 I am fairly convinced it is a problem with libdrm-intel1. If I revert back to 2.4.56-1~ubuntu2 by doing a sudo apt-get install libdrm-intel1=2.4.56-1~ubuntu2 it fixes my issue but not immediately. There seems to be some config related to this package that needs to be reset as well. For example, I un installed the alsa packages which forced me to re-install the ubuntu desktop. with libdrm-intel1=2.4.56-1~ubuntu2 installed, my system returned to normal. Upgrading that package and rebooting caused it to break again.
If anyone has any advice on how to further isolate what I think is a bug, I would appreciate it. Thanks.
Tomicus
You need to run these commands:
sudo apt-get install ppa-purge
sudo ppa-purge ppa:xorg-edgers/ppa
sudo apt-get purge nvidia*
sudo apt-get install nvidia-346 nvidia-prime
This will remove wrong drivers and install the correct ones.
Pilot6
  • 92,041
