51
I'm tailing a log file with -f flag. Then I'm piping this to grep, to find only lines that contain "X". That's working perfectly fine. Now I want to pipe this again into another grep, that will remove all the lines containing "Y". When I add the second pipe, the file stop refreshing and it looks like no data is coming.
This is the command that works: tail -f my_file.log | grep "X"
This is the command that doesn't: tail -f my_file.log | grep "X" | grep -v "Y"
How should I structure this so that the command works?
terdon
  • 104,119
Ori Horev
  • 513
As the output of grep is buffered, use --line-buffered option of grep to enable line buffering:
tail -f /path/to/log | grep --line-buffered 'X' | grep -v 'Y'
If your grep does not have the option, you can use stdbuf as an alternative:
tail -f /path/to/log | stdbuf -oL grep 'X' | grep -v 'Y'
heemayl
  • 93,925
22
I normally find more useful awk for these kind of logical checks:
tail -f /path/to/log | awk '/X/ && !/Y/'
#                   this I want    but not this
Tested by having two tabs, one in which I keep writing seq 20 >> myfile and the other one having for example tail -f myfile | awk '/3/ && !/13/'.
fedorqui
  • 10,699
15
Another approach would be to use a single grep invocation instead of two and so avoid the buffering issue. Just use a regular expressions that matches lines consisting of 0 or more non-Y characters, then an X and then 0 or more non-Ys again till the end of the line"
tail -f /path/to/log | grep '^[^Y]*X[^Y]*$'
terdon
  • 104,119
