-1
My laptop does not have an operating system because my daughter removed it. Can I install Ubuntu on to a flash drive?
Actully i have a windows 7 disc but after downloading that, the laptop asks for drivers to be installed but I do not have such a disc for the drivers. Any help will be greatly appreciated.
Arronical
  • 20,241
VIboy
Yes, you can install ubuntu from a thumb drive if you have access to some other working computer.
Download the ubuntu iso file, download the linux iso-to-usb writer program, write on usb drive, boot your computer without OS with that usb drive.
Two of the good programs to write Linux iso-to-usb are: http://unetbootin.github.io/ http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
beannayak
Yes you can install Ubuntu on to a flash drive. 32gb flash or above recommend. First burn Ubuntu install iso on a dvd, once complete boot computer with dvd select "try ubuntu". Next dowload gparted in software center on Ubuntu, partition flash drive in gparted. Once completed click on the install ubutu linknon desktop and follow prompts it should select the flash drive if you partitioned it correctly.
DnrDevil
  • 1,478
Yes, here are the instructions to install ubuntu on your computer as your operating system and start using this amazing OS. First you need to do this on another computer (I used a windows computer and this is what I did).
You will need:
  • A USB 3.0 with enough memory to allocate the image in it (about 8G)
  • A laptop hard drive enclosure
Steps:
  1. download the Universal-USB-installer http://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
  2. download the desktop 'disk image file' to a folder on the windows pc.
  3. insert the flash drive in your computer and open up the Universal-USB-Installer and agree with the terms.
  4. Select the linux system you will upload to the flash drive, browse and select the image, select the usb flash drive and check on formatting the drive.
  5. Click create and this will take a few minutes. When 'done' click close.
  6. restart your computer to reboot on your flash drive (if you don't know how to do this, ask me, or search the web).
  7. once the image is booted, click on install the image and connect your enclosure with your laptops hard drive in it and follow the step to install it in your hard drive.
