13
Once upon a time, I've installed Pantheon desktop on Ubuntu 14.04.
And then I decided to use vanilla desktop, Unity.
So I've removed all things related with Pantheon. I can't remember the exact command, but it seems like:
sudo apt-get remove pantheon*
When I open some apps which run with GUI from terminal, an error, a warning or a message is shown.
$ gedit
Gtk-Message: Failed to load module "pantheon-filechooser-module"
$ wireshark
$ nautilus
It seems it does not affect to the actual behavior of the system. But it is really annoying to me.
Is there anyone who can give me a tiny hint to solve this problem?
Jeon
  • 397
I had the same problem! If you run the following:
env | grep -i gtk
And see the module in your path like mine:
GTK_MODULES=pantheon-filechooser-module:overlay-scrollbar
Then it means it's being set somewhere to use the pantheon which needs to be removed. I did a quick grep and found the following:
/etc/profile.d/pantheon-filechooser-module.sh:export GTK_MODULES=pantheon-filechooser-module
So did:
sudo rm /etc/profile.d/pantheon-filechooser-module.sh
Finally - I saved my GTK_MODULES variable without the filechooser in my current session so not to have to restart: (obviously yours will be different to mine)
GTK_MODULES="overlay-scrollbar"
Job Done.
