Hej guys, yesterday I installed Ubuntu 14.04 on my Lenovo Yoga 13. This is the first time that I use Linux, so my experience in using Linux is not the best. My problem is that my built in bluetooth does not work. When I activate bluetooth in the control panel nothing happen. Maybe someone can help me? Thank u!
For:
lspci -knn | grep Net -A2; lsusb
I get:
Bus 004 Device 004: ID 5986:029c Acer, Inc
Bus 004 Device 003: ID 2047:0855 Texas Instruments
Bus 004 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 006: ID 04f3:000a Elan Microelectronics Corp.
Bus 003 Device 005: ID 0bda:1724 Realtek Semiconductor Corp.
Bus 003 Device 004: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 003 Device 003: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 003 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
For:
dmesg | grep -i blue
I get:
[ 2.666590] Bluetooth: Core ver 2.20
[ 2.666636] Bluetooth: HCI device and connection manager initialized
[ 2.667115] Bluetooth: HCI socket layer initialized
[ 2.667119] Bluetooth: L2CAP socket layer initialized
[ 2.667127] Bluetooth: SCO socket layer initialized
[ 2.689434] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.689437] Bluetooth: BNEP filters: protocol multicast
[ 2.689442] Bluetooth: BNEP socket layer initialized
[ 2.708230] Bluetooth: hci0: hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=1200
[ 2.713806] Bluetooth: RTL8723A: unexpected EPATCH signature!
[ 2.741344] Bluetooth: RFCOMM TTY layer initialized
[ 2.741354] Bluetooth: RFCOMM socket layer initialized
[ 2.741359] Bluetooth: RFCOMM ver 1.11
after firmware update:
[ 2.689988] Bluetooth: Core ver 2.20
[ 2.690009] Bluetooth: HCI device and connection manager initialized
[ 2.690057] Bluetooth: HCI socket layer initialized
[ 2.690061] Bluetooth: L2CAP socket layer initialized
[ 2.690067] Bluetooth: SCO socket layer initialized
[ 2.713594] Bluetooth: hci0: hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=1200
[ 2.726900] Bluetooth: RTL8723A: unexpected EPATCH signature!
[ 2.774790] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 2.774794] Bluetooth: BNEP filters: protocol multicast
[ 2.774799] Bluetooth: BNEP socket layer initialized
[ 2.806719] Bluetooth: RFCOMM TTY layer initialized
[ 2.806729] Bluetooth: RFCOMM socket layer initialized
[ 2.806744] Bluetooth: RFCOMM ver 1.11
and:
uname -r
3.19.0-30-generic
make ->
make -C /lib/modules/3.19.0-30-generic/build M=/home/bjoern/rtl8723au_bt modules
make[1]: Verzeichnis »/usr/src/linux-headers-3.19.0-30-generic« wird betreten
CC [M] /home/bjoern/rtl8723au_bt/rtk_btusb.o
/home/bjoern/rtl8723au_bt/rtk_btusb.c: In function ‘btusb_intr_complete’:
/home/bjoern/rtl8723au_bt/rtk_btusb.c:168:3: error: implicit declaration of function ‘hci_recv_fragment’ [-Werror=implicit-function-declaration]
if (hci_recv_fragment(hdev, HCI_EVENT_PKT,
cc1: some warnings being treated as errors
make[2]: *** [/home/bjoern/rtl8723au_bt/rtk_btusb.o] Fehler 1
make[1]: *** [_module_/home/bjoern/rtl8723au_bt] Fehler 2
make[1]: Verzeichnis »/usr/src/linux-headers-3.19.0-30-generic« wird verlassen
make: *** [all] Fehler 2
and for make install ->
mkdir -p /lib/firmware/rtk_bt
cp -f rlt8723a_chip_b_cut_bt40_fw_asic_rom_patch-svn8511-0x0020342E-20121105-LINUX_USB.bin /lib/firmware/rtk_bt/rtk8723a.bin
cp -f rtl8723a_config.bin /lib/firmware/rtk_bt/.
cp -f rtk_btusb.ko /lib/modules/3.19.0-30-generic/kernel/drivers/bluetooth/rtk_btusb.ko
cp: der Aufruf von stat für »rtk_btusb.ko“ ist nicht möglich: Datei oder Verzeichnis nicht gefunden
make: *** [install] Fehler 1
For
~/rtl8723au_bt$ ~/rtl8723au_bt$ cd ~/rtl8723au_bt; git checkout master && sudo make install
Bereits auf 'master'
Ihr Branch ist auf dem selben Stand wie 'origin/master'.
