I recently started reading structure and interpretation of a programing language and as such I want to install the mit-scheme interpreter but I realized whenever I installed it, it uninstalled postgres and whenever I installed postgres it uninstalled mit-scheme. My question is how can I install these two packages alongside each other seeing as I use both.
Martin
  • 113
If that problem is occurring on Ubuntu, most likely it is because you have 32 bit version of mit-scheme.
The problem is with packages libpq5:i386 and libpq5.
postgres depends on the latter and mit-scheme depends on the former package. So as soon as you install postgres, libpq5:i386 is removed to install libpq5. (Both x86 and x64 versions of libpq5 don't go together well, apparently.) And that removes mit-scheme because mit-scheme can no longer run.
So the solution is [Note - This solution is for Ubuntu only]-
  • Install postgres this uninstalls x86 mit-scheme and its dependencies.
  • Download x64 mit-scheme from here x64 mit-scheme.
  • Then run following commands.
sudo apt-get autoremove
sudo apt-get install libmcrypt4 libpq5
sudo dpkg -i /path/to/mit-scheme_9.1.1-5_amd64.deb
