I've read about a dozen sudo apt-get update questions and tried the solutions that were suggested there. None of them worked. I just installed Lubuntu 15.04 on my laptop, dual booting it alongside Windows 8. When I run sudo apt-get update I get these errors:
Err http://ph.archive.ubuntu.com vivid InRelease
Err http://ph.archive.ubuntu.com vivid-updates InRelease
Err http://ph.archive.ubuntu.com vivid-backports InRelease
Err http://ph.archive.ubuntu.com vivid Release.gpg
  Cannot initiate the connection to ph.archive.ubuntu.com:80 (2001:d18:0:23::172). - connect (101: Network is unreachable) [IP: 2001:d18:0:23::172 80]
Err http://ph.archive.ubuntu.com vivid-updates Release.gpg
Err http://ph.archive.ubuntu.com vivid-backports Release.gpg
Fetched 19.7 kB in 2min 0s (163 B/s)
Reading package lists... Done
W: Failed to fetch http://ph.archive.ubuntu.com/ubuntu/dists/vivid/InRelease
W: Failed to fetch http://ph.archive.ubuntu.com/ubuntu/dists/vivid-updates/InRelease
W: Failed to fetch http://ph.archive.ubuntu.com/ubuntu/dists/vivid-backports/InRelease
W: Failed to fetch http://ph.archive.ubuntu.com/ubuntu/dists/vivid/Release.gpg  Cannot initiate the connection to ph.archive.ubuntu.com:80 (2001:d18:0:23::172). - connect (101: Network is unreachable) [IP: 2001:d18:0:23::172 80]
W: Failed to fetch http://ph.archive.ubuntu.com/ubuntu/dists/vivid-updates/Release.gpg  Cannot initiate the connection to ph.archive.ubuntu.com:80 (2001:d18:0:23::172). - connect (101: Network is unreachable) [IP: 2001:d18:0:23::172 80]
W: Failed to fetch http://ph.archive.ubuntu.com/ubuntu/dists/vivid-backports/Release.gpg  Cannot initiate the connection to ph.archive.ubuntu.com:80 (2001:d18:0:23::172). - connect (101: Network is    unreachable) [IP: 2001:d18:0:23::172 80]
Here's my sources.list:
# deb cdrom:[Lubuntu 15.04 _Vivid Vervet_ - Release amd64 (20150422)]/  vivid main multiverse restricted universe
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://ph.archive.ubuntu.com/ubuntu/ vivid main restricted
deb-src http://ph.archive.ubuntu.com/ubuntu/ vivid main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://ph.archive.ubuntu.com/ubuntu/ vivid-updates main restricted
deb-src http://ph.archive.ubuntu.com/ubuntu/ vivid-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://ph.archive.ubuntu.com/ubuntu/ vivid universe
deb-src http://ph.archive.ubuntu.com/ubuntu/ vivid universe
deb http://ph.archive.ubuntu.com/ubuntu/ vivid-updates universe
deb-src http://ph.archive.ubuntu.com/ubuntu/ vivid-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://ph.archive.ubuntu.com/ubuntu/ vivid multiverse
deb-src http://ph.archive.ubuntu.com/ubuntu/ vivid multiverse
deb http://ph.archive.ubuntu.com/ubuntu/ vivid-updates multiverse
deb-src http://ph.archive.ubuntu.com/ubuntu/ vivid-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://ph.archive.ubuntu.com/ubuntu/ vivid-backports main restricted universe multiverse
deb-src http://ph.archive.ubuntu.com/ubuntu/ vivid-backports main restricted universe multiverse
deb http://security.ubuntu.com/ubuntu vivid-security main restricted
deb-src http://security.ubuntu.com/ubuntu vivid-security main restricted
deb http://security.ubuntu.com/ubuntu vivid-security universe
deb-src http://security.ubuntu.com/ubuntu vivid-security universe
deb http://security.ubuntu.com/ubuntu vivid-security multiverse
deb-src http://security.ubuntu.com/ubuntu vivid-security multiverse
## Uncomment the following two lines to add software from Canonical's
## 'partner' repository.
## This software is not part of Ubuntu, but is offered by Canonical and the
## respective vendors as a service to Ubuntu users.
deb http://archive.canonical.com/ubuntu vivid partner
deb-src http://archive.canonical.com/ubuntu vivid partner
Zanna
  • 72,312
I recommend you change your mirror service, as ph.archive.ubuntu.com doesn't seem to resolve, either because the subdomain has been dropped or there's some kind of weird proxy problem.
Solution: Replace all instances of ph.archive.ubuntu.com with archive.ubuntu.com i.e. remove ph. from the urls, leaving everything else as it is.
