Ubuntu 14.04
Basically I am trying to accomplish the following setup -
wireless internet ---> wlan0 of Ubuntu computer "bridged to" wlan1 of same Ubuntu computer ---> device with wifi
The reason for this setup is that the wireless internet is a WPA2 Enterprise network which my device with wifi cannot connect to. (The device with wifi also cannot connect to peer-to-peer networks or ad-hoc networks.) Also, the wireless internet source has no whitelist / blacklist and therefore there is no issue with it seeing the device's MAC address (if necessary), and no issue with it assigning an IP address to the device (if necessary). It is the device that has an issue with WPA2 Enterprise authentication.
[EDIT - As the device cannot successfully authenticate, the wireless internet source is NOT likely to assign an IP address to the device, and also likely to take issue with seeing the device's MAC address.]
wlan0 is an Intel wireless chipset / interface which cannot be set to either access point mode or master mode, and therefore is used to connect to the WPA2 Enterprise internet source.
wlan1 is to be set to access point mode.
Obviously, the "bridge" between wlan0 and wlan1 is not meant to be wireless, as both are on the same computer.
(1) I believe brctl cannot bridge a wireless interface (wlan0) to another wireless interface (wlan1). Is this correct?
(2) If brctl cannot be used, can I still use hostapd?
(3) If brctl cannot be used, what should I be looking for to accomplish the setup described above?
(4) Would any of the following be a part of the solution to my problem - (a) dnsmasq to serve DHCP (b) hostapd (c) static IP address (for wlan1 ???) (for the device connected to wlan1 ??) (d) NAT (Network Address Translation) (e) iptables (f) IP Masquerade (g) sudo iw set dev wlan0 4addr on (h) WDS (wireless distribution system) (i) IP Forwarding ?
Thank you.
sean
  • 51
The requirement here is that all interfaces must be able to send packets with any source MAC address, and receive packets with any destination MAC (not just the device's own).
Wi-Fi AP interfaces can be bridged just fine (most "wireless routers" in fact have a plain Linux bridge between AP and Ethernet). Station-mode interfaces, however, cannot. So you can bridge wlan1 but not wlan0.
There's a way around it – the "4addr" mode aka "WDS" mode, which adds an extra MAC address field to Wi-Fi frames. You can enable it via iw, as long as your Wi-Fi driver supports it. Once enabled, you will be able to bridge wlan0 as well.
However, for security reasons, many APs don't allow 4addr mode by default. (Some have a general toggle, some have a MAC-based whitelist.) Will it work with your university AP? Try it and see.
(Another workaround is "arpnat" – like NAT but applied to MAC addresses – but it can confuse DHCP servers, and it's not supported by regular Linux anyway. Some APs, like PicoStation, support it in station mode.)
Depends on your Wi-Fi driver. Most of them should support AP mode nowadays, but not all do. Use iw phy0 info, iw phy1 info to find out.
The most common alternative approach would be IP NAT (masquerading) using iptables.
In some cases, regular routing (without NAT) would also work.
yes, no, no, yes, maybe, maybe, what, uh, are you just throwing assorted terms here?
user1686
  • 645
You can bridge wireless interfaces using brctl without any problem:
brctl addbr br_name
brctl addif br_name wlan0
brctl addif br_name wlan1
But you will need to refer the bridge br_name itself, not to the separate interfaces in you network config.
Fabby
  • 35,017
Pilot6
  • 92,041
