I want the change the permissions of /dev/ttyACM0 from a script.
I have tried this command:
su -c "chmod -R 777 /dev/ttyACM*" -m "$user".
When I execute the script it is asking for a password. I want run this without being prompted for password.
I tried adding an user in /etc/sudoers, but it doesn't work.
It is a CGI script. It is not working external requests (i.e. from other IPs).
user ALL= (user)  NOPASSWD: /usr/lib/cgi-bin/test.cgi
How can I do change the permissions so that anyone can execute the script from other IP addresses?
kos
  • 41,268
You haven't said why the sudo solution doesn't work, but troubleshooting sudo is rather onerous. This test line in /etc/sudoers worked for me
cgiuser ALL = (root) NOPASSWD: /bin/chmod -R 777 /tmp/xxx*
so give it a try. Your /etc/sudoers line would be
user ALL = (root) NOPASSWD: /bin/chmod -R 777 /dev/ttyACM*
and your script would have
/usr/bin/sudo /bin/chmod -R 777 /dev/ttyACM*
Just make sure that the script runs as user, for a cgi script it's probably apache or www-data.
PS: The previous answer is just wrong. Provided that you belong to the sudo group or otherwise have the privileges, sudo su - works perfectly to become root, even if no root password is set. sudo -s is probably better, however. YMMV
nortally
  • 161
