I'm new to Ubuntu and not a programmer, although I am definitely learning a few things on these boards... I am running 14.04 and trying to download Google Chrome, but I get this error when I try to download it in the software center:
Dependency is not satisfiable: libappindicator1
Error
Any ideas? I can give you more information if necessary. Thanks!
TheWanderer
  • 19,525
  • 52
  • 65
When I installed Ubuntu for the first time, I had the same dependency problems as you while installing the Chrome .deb file (before running update)
Therefore, press Ctrl+Alt+T to go to a terminal and run:
sudo apt-get update
sudo apt-get upgrade
... as that will install required dependencies.
Then just install chrome from the Software Centre.
Fabby
  • 35,017
Ravan
  • 9,567
You need to run first this command:
sudo apt-get install libxss1 libappindicator1 libindicator7
Follow this answer to install chrome
This should be fixed by running
sudo apt-get install -f
When you install 3rd party packages, the dependencies do not install automatically.
Pilot6
  • 92,041
