I've misspelled user name when installing Ubuntu and would like to rename if possible. How can I safely change my user name?
Safely? Don't rename at all. Instead, (make sure the user is logged out first) create a new user with the correct username, rename the old home directory to the new username and chown -R the folder to the new user.
This assumes that you're not using encrypted homes. That would require some different steps, but since I haven't done that myself, I'll leave that to someone else.
- 29,687
I have recently faces such problem and got working solution.
Make backup of the users- and groups-related files
sudo cp /etc/passwd ~/passwd.bak sudo cp /etc/group ~/group.bak sudo cp /etc/subuid ~/subuid.bak sudo cp /etc/subgid ~/subgid.bak sudo cp /etc/gshadow ~/gshadow.bak sudo cp /etc/shadow ~/shadow.bakWe need to boot in Recovery mode (click Shift on boot, in GRUB select Advanced options for Ubuntu, select Ubuntu, with Linux ... (recovery mode))
- Select
root Drop to root shell promptto access root-shell Enter your main user (usually GID = 1000, member of sudo group) password here when asked
Press Enter for maintenance (or press Control-D to continue):Remount all filesystems with read and write
mount -o rw,remount / mount -o rw,remount /homeRename user from old_user to new_user, rename comment on user-name (field 5 in
/etc/passwd) and move its homeOLDNAME="old_user" NEWNAME="new_user" usermod -l $NEWNAME $OLDNAME -c $NEWNAME -d /home/$NEWNAME -mRename user's group from old_user to new_user
groupmod $OLDNAME -n $NEWNAMEReplace old_user to new_user in
/etc/subgidand/etc/subuidsed -i "s/$OLDNAME/$NEWNAME/g" /etc/subuid sed -i "s/$OLDNAME/$NEWNAME/g" /etc/subgidReboot the system and then login with new_user name and old password. Optionally change password with
passwdIf goes right - remove backed-up files:
sudo rm ~/passwd.bak ~/group.bak ~/subuid.bak ~/subgid.bak \ ~/gshadow.bak ~/shadow.bak
Note: you can read about used options of usermod and groupmod on their man-pages.
- 103,263
