I have samba installed on ubuntu 14.04 and I want it to start on system boot. Anybody help?
Simply run the following command in a terminal :
sudo update-rc.d samba defaults
hg8
  • 13,582
You can try the following ways. I don't know about samba, but it worked for me in running some other services.
There are three ways to do it.
Alternative 1# Creating New Script in /etc/init.d/
We can create new startup service by creating a new script inside the init.d
directory
Note: Donot forget to make the script executable
Alternative 2# By adding commands to /etc/rc.local
The technique is illustrated by the following example :
vi /etc/rc.local
/path/to/my/script.sh || exit 1
exit 0
Alternative 3# The third way to achieve that is by adding an Upstart Job
    Create      /etc/init/myjob.conf
Add the following entries to the file
description "my Job"
start on startup
task
exec /path/to/my/script.sh
Here in description you can use any name. In the path of exec give the path of the samba binary.
Bidyut
  • 789
  • 14
