When I mount a server file system that is located in a local network over nfs on my laptop, the processes interacting with the filesystem freeze / hang up whenever the network connection is lost. The file explorer (Dolphin) window freezes, and through the terminal I cannot display the contents of the directory that contains the mount point. Trying to sudo umount the folder won't work.
In my case, I use sudo mount -t nfs 192.168.1.100:/elrudi /home/elrudi/nas. I can still cd to any location, but when I try to ls the contents of /home/elrudi, the terminal window hangs. All I can do is force-close the affected windows. When opening a new dolphin/terminal window, the problem persists.
Some observations:
- If the network connection gets restored, the problem goes away - most of the times. Curiously, dolphin seems to need a little kick to unfreeze, which can be administered by
lsing/home/elrudiin a terminal. - If the network connection cannot be restored, however, such as when it is out of reach, there is nothing that can be done (that I know of). Even rebooting the system is not an option, as it hangs at the 'final' screen ('ubuntu' with process progress dots that light up one after the other).
I'd like to know if there is a way to make a more robust mount, or if there is something I can do to make the system responsive again.
Thanks!
