The screen is now 1024x768 (4:3) resolution, and I can't change that, when I turn on my computer a boot error shows up, maybe this two problems are matches, but I'm not too sure...
(ACPI PCC probe failed)
Than my computer turn on with this low res. and I can't even change it on the NVIDIA settings, because when I change the "ViewPortIn" to 1920x1080, the panning change, but that's not a problem, the "ViewPortOut" not changes, and that's the problem, first I tried to change it manually, but when I press to a another box, or I hit apply than it change back the numbers again, so I have no idea how to fix this problem.
(I used X.Org X server driver, and that problem wasn't there, I could run the screen in 1920x1080!)
The easiest thing to do is add the resolution using xrandr - this is a good guide. You would then need to add the xrandr configurations to a startup file, so that you'll get your desired resolution upon reboot/startup:
  • Create a bash script, xrandr.sh for example, and place your xrandr commands into it:
    #!/bin/bash
    sudo xrandr --newmode "1920x1080_60.00" 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync
    sudo xrandr --addmode Virtual1 1920x1080_60.00
    xrandr --output Virtual1 --mode 1920x1080_60.00
  • Make the script executable with chmod +x xrandr.sh
  • Search for "Startup Applications" in the dash, run it, and add the script as a startup application.
The commands will now run every time you log into your account.
OR you can go the easy way and use a program that does the above for you - ResolutionX.
TellMeWhy
  • 17,964
  • 41
  • 100
  • 142
