I tried following the directions in this post Installing latest version of R-base after several simpler techniques failed to upgrade my R (which is stuck on 3.0.2). Everything seems to have worked until the last instruction: sudo apt-get install r-base, which led to this message:
ubuntu@ip-10-0-1-108:/srv/shiny-server/atomic_junctions$ sudo apt-get install r-base
Reading package lists... Done
Building dependency tree
r-base : Depends: r-base-core (>= 3.2.2-1precise0) but it is not going to be installed
Depends: r-recommended (= 3.2.2-1precise0) but it is not going to be installed
Recommends: r-base-html but it is not going to be installed
I thought this meant I needed to install the mentioned dependencies. I kept getting more and more errors relating to one package needing another until I gave up when trying this:
sudo apt-get install r-base r-base-core r-recommended r-base-html r-base-dev
which still leads to errors:
r-base-core : Depends: libtiff4 but it is not installable
So now I just don't have R installed at all. I need to upgrade as some packages I am using are not available for this old version of R. Any help/recommendations would be appreciated. Thanks.
