I run
sudo apt-get update
which returns these failures at the end:
W: Failed to fetch httpe://archive.ubuntu.com/ubuntu/dists/raring/main/binary-amd64/Packages  Protocol httpe not supported or disabled in libcurl
W: Failed to fetch httpe://archive.ubuntu.com/ubuntu/dists/raring/multiverse/binary-i386/Packages  Protocol httpe not supported or disabled in libcurl
E: Some index files failed to download. They have been ignored, or old ones used instead.
How can I fix this problem? I've looked all around and can't seem to find an answer.
After running
lsb_release -a
No LSB modules are available.
Distributor ID:    Ubuntu
Description:    Ubuntu 14.04.3 LTS
Release:    14.04
Codename:    trusty
One simple command, httpe isn't a valid protocol:
sudo sed -i 's/httpe:/http:/g' /etc/apt/sources.list
sudo apt-get update
And now, it seems, that you have Trusty installed and Raring repositories in your sources.list
If you do not need this repositories, then remove the lines with
sudo sed -i '/raring/d' /etc/apt/sources.list
A.B.
  • 92,125
