Some time ago, I had installed NVIDIA-Linux-x86_64-352.30.run
It seemed to work. Certainly I was able to login and graphics was working. All of a sudden, One day I rebooted and the screen resolution was different. My login does not work. I logged in under console and found that the reason appears to be the following message in dmesg:
NVRM: The NVIDIA GPU 0000:01:00.0 (PCI ID: 10de:1381)
NVRM: installed in this system is not supported by the 304.128 NVIDIA Linux driver release.....
Does this mean the newer driver suddenly disappeared? I really don't know what 304.128 is, but it sounds old. I will install the latest, but this makes me extremely suspicious of my computer.
Note that when I boot into Windows everything works fine in 3800x2160 x 30Hz mode. That is definitely the NVIDIA driver under Linux, and the hardware does not appear to be the problem.
TellMeWhy
  • 17,964
  • 41
  • 100
  • 142
Dov
  • 833
Either due to a kernel update, or corruption, the NVIDIA driver I had manually installed seemed to evaporate. Installing from the repository should be a good way to keep it there:
sudo ubuntu-drivers devices
lists out the packages available, of which the best (at the time of writing) was:
sudo apt-get install nvidia-346
Note this is not the most recent driver, but it's one that is in standard repositories, so it will continue to get updated which is fine with me.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Dov
  • 833
