I was using compiz config and now I can't access anything. What can I do to fix this? I was thinking restarting the configuration to factory configuration. Is it possible to enter Ubuntu using terminal?
Edit: Since you're unable to access the GUI desktop / are stuck in a login loop, and following up on David Cole's later post, you can remedy theĀ Compviz misconfiguration by first accessing a Terminal at the login screen by holding Ctrl + Alt + F1 (alternatively, Ctrl + Alt + F2 , or + F3 ).
Once in Terminal issue the following command to reset Compviz:
dconf reset -f /org/compiz/
Now, reboot your system by typing:
sudo reboot now
This should have returned Compviz to its default, post-install state.
Finally, proceed with David Cole's above mentioned instructions to set the default display manager.
Reference: How-To-Geek
- 72
Note: this fix will work only after completing the steps outlined in mheadroom's post.
From your login screen press and hold Ctrl + Alt + F1 to load a non-graphical terminal. If that key combination doesn't work, try Ctrl + Alt + F3 instead.
Once in terminal type:
sudo apt-get install gdm && sudo dpkg-reconfigure gdm
Then select gdm and hit Enter . Now:
sudo shutdown now -r
And wait for your system to reboot. Bam! You're done!
