I've Ubuntu 11.10 and my problem is about the touchpad. At the beginning of my computer it's works fine, but after opening an application or a few minutes, it stops working and I have to use a USB mouse. Someone could help me? Thank you very much:)
jrg
  • 61,707
5 Answers5
12
There is another command that works, and is perhaps more direct:
sudo modprobe -r psmouse && sudo modprobe psmouse
The problem is that it is not a permanent solution. I already tried adding psmouse to the /etc/modules file, but the problem is not about the driver not loading, but crashing or something.
Does the unity replacement command work as a "permanent solution"?
Severo Raz
  • 6,111
If this happents, use Ctrl+Alt+T to open a terminal and type:
synclient TouchpadOff=0
Peachy
  • 7,235
  • 40
  • 47
josh
  • 71
These solutions didn't work for me (running ubuntu 12.10). The thing that did the trick is:
gsettings set org.gnome.settings-daemon.peripherals.touchpad touchpad-enabled true
Good luck!
Kris
  • 1,078
I had the same problem as well, the only thing that I did was in the terminal:
    unity --replace
after that it hasn't been an issue.
st2011
  • 623
I was sucessful with the wollowing treatment: I plugged in a USB mouse Navigate to the touchpad and mouse settings (top right button -> system settings -> Mouse and Touchpad) I then unchecked the disable mouse when typing option. Reboot.
Worked fine using this since! Perhaps there is some weird mouse locking issue related to this setting?
meawoppl
  • 1,054
