I used the wrong channel for my Nexus 4; How do I upgrade it, and what channel do I use?
Backstory:
  • Followed this tutorial: https://developer.ubuntu.com/en/start/ubuntu-for-devices/image-channels/
  • Have Nexus 4, so I chose the following option:
    Nexus 4 | Track the latest development | ubuntu-touch/devel/ubuntu
  • ubuntu-touch/devel/ubuntu turned out to be a very old image.
  • Popey advised to use ubuntu-touch/rc/bq-aquaris.en for Nexus 4
  • Trying to upgrade, ran into a few problems.
Questions
  • Do I have to completely reflash my phone?
  • Do I run the commands from phone, or computer?
  • What commands do I use?
  • What do the following errors mean?
`2015/10/04 09:01:21 Start pushing /home/akiva/.cache/ubuntuimages/ubuntu-touch/rc/bq-aquaris.en/mako/version-25.tar.xz to device`
`2015/10/04 09:01:21 error pushing:`
and
`2015/10/04 08:48:24 Expecting the device to expose an adb interface...`
`device cannot be detected over adb`
Anon
  • 12,339
Solution
No. Once you have ubuntu on there, you can simply update.
Computer, with phone plugged in.
  • What command do I use?
Boot up phone up normally, and run this command from your computer:
adb reboot recovery
Wait until the phone gets into recovery mode, and run this command:
ubuntu-device-flash touch --channel=ubuntu-touch/rc/bq-aquaris.en
Possible Errors
$ubuntu-device-flash touch --channel=ubuntu-touch/rc/bq-aquaris.en
This is because you are logged into the phone. You need to log into recovery mode with the command: adb reboot recovery
You are probably in the Bootloader instead of recovery mode. You won't be able to connect to adb there. If not this, you could also try the command:
adb wait-for-device
and try plugging it in until it is noticed.
Anon
  • 12,339
If your phone can boot into Ubuntu, just enter the developer mode by selecting 'settings>About>Developer Mode' and then connect your device to your PC and run 'ubuntu-device-flash' as described by Akiva.
If you get errors try running 'ubuntu-device-flash --clear-cache touch'.
Or check if your device is really connected with 'adb devices'. This should list all connected devices. with
-- I have just now no PC here, so all commands are just written by mind. Gonna check this tomorrow, soon.
eDeviser
  • 2,149
  • 24
  • 37
