I can open only some folders which are on desktop, but anyway they are without action buttons. When I try to run some programms like "google chrome", or "ccsm" via terminal (ctrl+alt+f1), i got error: GtkWarning: could not open display. Trying to run command: sudo dpkg-reconfigure compiz , got answer:
/var/lib/dpkg/info/compiz.config: 1: /var/lib/dpkg/info/compiz.config: [general]: not found
/var/lib/dpkg/info/compiz.config: 2: /var/lib/dpkg/info/compiz.config: backend: not found
/var/lib/dpkg/info/compiz.config: 3: /var/lib/dpkg/info/compiz.config: plugin_list_autosort: not found
/var/lib/dpkg/info/compiz.config: 5: /var/lib/dpkg/info/compiz.config: [gnome_session]: not found
/var/lib/dpkg/info/compiz.config: 6: /var/lib/dpkg/info/compiz.config: backend: not found
/var/lib/dpkg/info/compiz.config: 7: /var/lib/dpkg/info/compiz.config: integration: not found
/var/lib/dpkg/info/compiz.config: 8: /var/lib/dpkg/info/compiz.config: plugin_list_autosort: not found
/var/lib/dpkg/info/compiz.config: 9: /var/lib/dpkg/info/compiz.config: profile: not found
/var/lib/dpkg/info/compiz.config: 11: /var/lib/dpkg/info/compiz.config: [general_ubuntu]: not found
/var/lib/dpkg/info/compiz.config: 12: /var/lib/dpkg/info/compiz.config: backend: not found
/var/lib/dpkg/info/compiz.config: 13: /var/lib/dpkg/info/compiz.config: integration: not found
/var/lib/dpkg/info/compiz.config: 14: /var/lib/dpkg/info/compiz.config: plugin_list_autosort: not found
/var/lib/dpkg/info/compiz.config: 15: /var/lib/dpkg/info/compiz.config: profile: not found
Guest session and other user session are working, but main (mine) is not. What can i do ?
To open an application from tty1 (CTRL + ALT + F1) in your xsession (CTRL + ALT + F7), you must first export the display variable which specifies the xsession. Here's an example. Press CTRL + ALT + F1 and sign in with your username and password. Then, run the following command:
export DISPLAY=:0
Now you may execute the command to run the application and it should open in your xsession:
ccsm
and press CTRL + ALT + F7 to return to the xsession.
Now, scroll down to the unity plugin and enable it.
Please post any errors, don't worry about warnings.
mchid
  • 44,904
  • 102
  • 162
Found resolution from other question answer:
After many spent days and many SO threads read, I found that this seems to be an Ubuntu open Bug (Status 'Incomplete' as of Juli 2015). More information about it here: bugs.launchpad.net/ubuntu/+bug/1285444 The quick solution seems to be: $ mv ~/.config/dconf/user ~/.config/dconf/user.old – julianromera Jul 8 at 19:04
For me, answer is:
But default icons are displayed in left panel, not mine i was sorted earlier.
