I access my contacts via WebDav on the work LAN in evolution. Recently these contacts are also available via https and client certificate.
I have added the certificate authority and client certificate as shown in the pic below:
The addressbook is added as Type WebDav/Use a secure connection.
However, I still get the following handshake failed errors:
Unable to open address book
This address book cannot be opened. This either means that an incorrect URI was entered, or the server is unreachable.
Detailed error message: Unable to connect to 'xyz': Error performing TLS handshake: Decryption has failed.
(The same certificate and CA work perfectly in Firefox, also accessing the same addressbook and calendar with the same tls client certificate works perfectly on my Android device, the calendar leads to the same problem, the server runs egroupware)
