I'd like to preview files using Gloobus-Preview in Ubuntu 11.10 but I can't figure out how to do it. And I don't want to use gnome-sushi...
Asked
Active
Viewed 2,235 times
muru
- 207,228
Paul McDonald
- 230
It appears a solution was just posted over at Web Upd8. Gloobus-Preview now has a new package called gloobus-sushi meant for this purpose.
In summary, you'll need to run the following commands:
sudo add-apt-repository ppa:gloobus-dev/gloobus-preview
sudo apt-get update
sudo apt-get install gloobus-preview gloobus-sushi libgdk-pixbuf2.0-dev
Knowledge Cube
- 14,911
if you have Thunar file manager you can use gloobus-preview by setting a custom action: first, download gloobus-preview:
then, in thunar set a custom action in menu -> edit -> configure custom actions
Description: preview the file using gloobus
previewCommand: gloobus-preview %f
In the appearence and conditions tab select all the checks.
For access to gloobus preview unfortunately you need use right click menu in the latest options. Now if you want to preview a file right click it and select the custom action.
ipatch
- 103
William Trigos
- 111
