I have Lenovo G510 with Ubuntu 15.04, and I just don't see the bluetooth (It did worked it the past)
elichai2@Lenovo-G510:~$ uname -a
Linux Lenovo-G510 3.19.0-30-generic #33-Ubuntu SMP Mon Sep 21 20:58:04 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
elichai2@Lenovo-G510:~$ sudo rfkill list all
0: ideapad_wlan: Wireless LAN
        Soft blocked: no
        Hard blocked: no
1: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
elichai2@Lenovo-G510:~$ sudo lshw -C network
  *-network
       description: Wireless interface
       product: AR9485 Wireless Network Adapter
       vendor: Qualcomm Atheros
       physical id: 0
       bus info: pci@0000:02:00.0
       logical name: wlan0
       version: 01
       serial: b8:ee:65:61:57:f6
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list rom ethernet physical wireless
       configuration: broadcast=yes driver=ath9k driverversion=3.19.0-30-generic firmware=N/A ip=10.0.0.10 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
       resources: irq:17 memory:b0500000-b057ffff memory:b0580000-b058ffff
  *-network
       description: Ethernet interface
       product: QCA8172 Fast Ethernet
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: eth0
       version: 10
       serial: f8:a9:63:25:b4:13
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm pciexpress msi msix bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=alx latency=0 link=no multicast=yes port=twisted pair
       resources: irq:30 memory:b0400000-b043ffff ioport:3000(size=128)
elichai2@Lenovo-G510:~$ sudo service bluetooth status
● bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
   Active: inactive (dead)
elichai2@Lenovo-G510:~$ sudo service bluetooth restart
   Active: active (running) since Thu 2015-10-01 11:20:28 IDT; 2s ago
 Main PID: 1294 (bluetoothd)
   CGroup: /system.slice/bluetooth.service
           └─1294 /usr/sbin/bluetoothd -n
Oct 01 11:20:28 Lenovo-G510 bluetoothd[1294]: bluetoothd[1294]: DIS cannot start: GATT is disabled
Oct 01 11:20:28 Lenovo-G510 bluetoothd[1294]: bluetoothd[1294]: Failed to init deviceinfo plugin
Oct 01 11:20:28 Lenovo-G510 bluetoothd[1294]: bluetoothd[1294]: Failed to init proximity plugin
Oct 01 11:20:28 Lenovo-G510 bluetoothd[1294]: bluetoothd[1294]: Failed to init time plugin
Oct 01 11:20:28 Lenovo-G510 bluetoothd[1294]: bluetoothd[1294]: Failed to init alert plugin
Oct 01 11:20:28 Lenovo-G510 bluetoothd[1294]: bluetoothd[1294]: Failed to init thermometer plugin
Oct 01 11:20:28 Lenovo-G510 bluetoothd[1294]: Failed to init gatt_example plugin
Oct 01 11:20:28 Lenovo-G510 bluetoothd[1294]: Bluetooth Management interface initialized
Oct 01 11:20:28 Lenovo-G510 bluetoothd[1294]: bluetoothd[1294]: Failed to init gatt_example plugin
Oct 01 11:20:28 Lenovo-G510 bluetoothd[1294]: bluetoothd[1294]: Bluetooth Management interface initialized
elichai2@Lenovo-G510:~$ sudo lsusb
Bus 004 Device 002: ID 8087:8000 Intel Corp.
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 8087:8008 Intel Corp.
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 003: ID 174f:114f Syntek
Bus 001 Device 006: ID 05c6:6765 Qualcomm, Inc.
elichai2@Lenovo-G510:~$ dmesg | grep -i firmware
[    0.213404] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[    5.659575] psmouse serio1: elantech: assuming hardware version 3 (with firmware version 0x450f03)
elichai2@Lenovo-G510:~$ dmesg | grep -i blue
elichai2@Lenovo-G510:~$ lsmod | grep blue
If anyone have any idea how to fix it I would love to hear (I'm willing to even recompile the whole system if you have a patch) Thanks!
P.S: I ran dmesg | grep -i blue again and now i've found these lines:
[    4.780100] usb 1-7: Product: Bluetooth USB Host Controller
[   16.342944] Bluetooth: Core ver 2.20
[   16.342958] Bluetooth: HCI device and connection manager initialized
[   16.342962] Bluetooth: HCI socket layer initialized
[   16.342964] Bluetooth: L2CAP socket layer initialized
[   16.342968] Bluetooth: SCO socket layer initialized
and running lsmod | grep blue came back with new result:
bluetooth             491520  2 ath3k,btusb
And Bluetooth just got back to rfkill :)
elichai2@Lenovo-G510:~$ rfkill list
        Soft blocked: no
        Hard blocked: no
1: ideapad_bluetooth: Bluetooth
        Soft blocked: yes
        Hard blocked: no
2: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
elichai2
  • 691
  • 14
With the latest edit, all you need to do is open a terminal window and enter
rfkill unblock all
And if it doesn't fix the bluetooth, it is likely because you don't have firmware installed
sudo apt-get install linux-firmware
sudo modprobe -r btusb
sudo modprobe -r ath3k
sudo modprobe ath3k
sudo modprobe btusb
Jeremy31
  • 13,293
