On the right click menu (in Nautilus, desktop, etc), there is a "compress" option. Is there any way to make "zip" the default format for this?
Jorge Castro
  • 73,717
After some investigating, it appears that this is controlled by a gconf setting. To set zip as the default compression method, hit Alt+F2 to launch the 'Run Application' window. Type 'gconf-editor' in the box and hit the 'Run' button. This can be seen in the screenshot below.
Run Application Window
Once you hit the 'Run' button, a window like the one below will appear. This is the Configuration Editor.
The compression feature of nautilus really uses file-roller. To get to the file-roller settings, start by expanding the 'apps' folder.
Apps Folder
Next, find and expand the 'file-roller' folder.
file-roller folder
Expand the 'dialogs' folder.
dialogs folder
Select the 'batch-add' folder.
batch-add folder
You should now see an item with the name of 'default_extension' in the section on the right. You will want to click on the 'Value' field and change whatever was previously there to '.zip'.
default_extension = .zip
Now, if you close the configuration editor and open nautilus, .zip should be the default compression method.
.zip is default compression method in nautilus
nhandler
  • 2,526
Well, when you click on «compress» it will show you a window to select the format. The file format is the last chosen format.
